Nitrous Oxide - got a n02 idea . . . would it work?
camaroextra
12-04-2005, 11:21 PM
is it possible to inject n02 straight into the fuel system and have it enter the cylinder through the fuel injector? you would obviously need larger injectors and some computer work but i think its a good idea. you would get no manifold pooling that can occur with a wet system. you could have a more perfect fuel/n02 mix that a dry system may strugle with. it would equalize the n02 through all the cylinders like a direct port system, but would eliminate the possible atomization problems because the injector atomizes the fuel. it could also be super stealthy. what do you think?!?!? constructive criticism please.
white2001s10
12-04-2005, 11:26 PM
I say No you can't. I'd bet money it wouldn't work out. I could see fuel gelling and N2O ice forming in the injector and clogging it good. The N2O pressure would far overpower the fuel pressure & no telling what that would do but I'd bet there would be little fuel flow.
Direct port solves all those problems and is readily available to anyone.
(Not an expert, but): No.
Look at it this way: Consider that N20 needs to be in the neighborhood of 1000psi to stay liquid. Your fuel system is around 55psi. If you wanted to run at 1000psi, good luck on finding a fuel injector :). OTOH if you wanted to inject gaseous N20 into the fuel rail, well sounds like a disaster waiting to happen to me.
hondo
12-04-2005, 11:41 PM
the closest you're gonna get to that is an nxl or noszzle which is basically a dp that mounts the nozzle right under the injector. also what makes you think dry kits have trouble maintaining a good a/f ratio?
heh injectorsicle :jest:
sprayinss
12-05-2005, 01:26 AM
no way man thats never guna work,goodluck with it
camaroextra
12-05-2005, 09:21 AM
ok just wondering
BigSteele
12-05-2005, 11:07 AM
think of it like the injectors would have to be nitrous solenoids, and it would make more sense to just have 1 noid and run a junction and then direct port nozzles. So i think DP is the much better solution.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
