whats the difference in the castings 241 243 853?
Old 12-05-2005, 09:49 PM
02blkws6vert's Avatar
Default whats the difference in the castings 241 243 853?
just curious what is best for my 02 ta? whats all the differences?
Old 12-05-2005, 10:24 PM
BriancWS6's Avatar
241 castings: 01 and 02 F-bodies
243 castings: LS6 heads (ZO6 heads)
853 castings: 98-00 F-bodies
The 241s are better than the 853s, and the 243s are better than the 241s.
Old 12-05-2005, 11:46 PM
BadBowtie03's Avatar
the 98-00 cars had differnt heads then the 01 02 cars?? Why are they better? Do they flow any different? Thanks!
Old 12-06-2005, 12:30 AM
dlandsvZ28's Avatar
FYI...with 853's you will have to get perimeter type valve covers and different coil pack brackets.
Old 12-06-2005, 04:29 AM
transAm-98's Avatar
i just swaped my 853's out for stock 243's. and you have to buy coil brakets to mount the coils and get the center bolt valve covers cause the old perimiter style don't work. so it cost a couple extra bucks. but the 243's have bigger valves and ports . i felt a very nice gain all the way through the RPM's. and at low rpm's it is much smoother (this is with a cam by the way). i picked them up brand new, and dirt cheap on E-bay. worth every penny.
Old 12-06-2005, 05:08 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
they progressively got better throughout the years.
Old 12-06-2005, 09:04 AM
is that because you have a 98? wouldnt the heads just go right on my car without modifying coil brackets? i have a 02
Old 12-06-2005, 09:29 AM
badaSS346's Avatar
I have 241's on my 2000
Old 12-06-2005, 09:55 AM
HawkFanatic's Avatar
I believe the center bolt pattern is 98 only
Old 12-06-2005, 10:27 AM
jmm98LS1's Avatar
Nope, 98's are the only year with perimeter bolt pattern valve covers. 99 up got centerbolt style.
