Changing Cutoff Switch To Conv. Switch
Can Anyone Give Me The Link That Shows The Wiring Diagram To Change The Qtp Elct. Exhaust Cutoff Switch To A Stock Convertible Switch.
A friend of mine gave me this today - excerpt from a thread on the old ls1.com in May 2003:
Use GM harness PN 15306189 - plugs into the back of the conv switch.
Pin B - Illumination
Pin C - Illumination ground
Pin H - Ground
Pin D - Ground
Pin F - Ignition
Pin E - Cut out motor
Pin A - Cut out motor
Don't know if this will help but thought I'd post it.
Pin H - Ground
Pin D - Ground
Pin F - Ignition
