et fronts vs radial front runner
the price difference and street perfromance are noticably different too..
if its 18lbs total then, its prolly worht the money if you'll only be running down the track on them
The problem comes when you want to make a turn they will roll over on the sidewall. Thye're made to go straight.....not turn.
Originally Posted by Hawkn01
Good advice ! The front runners are designed for track use only and have very weak sidewalls. They have a 3000lb rating. Most street cars weigh much more than that.
