ls6 cam in a 5.3l
Old 12-07-2005, 09:18 AM
91redchevy's Avatar
Default ls6 cam in a 5.3l
I am thinking about putting an ls6 cam #12560950 in the 5.3 that i am building to
go in my '91 silverado. What kind of gains would i see over the stock cam? This is
my first lsx type engine so i'm new to which swaps work the best. Any info would be
greatly appreciated.
Old 12-07-2005, 10:54 AM
SUTTERERMAN85's Avatar
there are better choices out there that are more performance oriented. but for the money it can be a good upgrade. not sure on how much you will pick up though. the good thing is you can run a stock tune with it. it depends if you are wanting it to lope or sound stock. what are the stock specs of the 5.3?
Old 12-07-2005, 11:00 AM
PREDATOR-Z's Avatar
That cam likes to rev higher and makes power higher in the band.
I think you should get something more suited to your trucking purposes.
Like something with more trq under the curve. Check VINCI truck cams>>>>
Old 12-07-2005, 11:28 AM
91redchevy's Avatar
Thanks, i was wondering how much higher it would move the powerband. The truck is going
to be a hotrod/daily driver so i would like a little more zip. I also forgot to mention i'm going
with a carburetor setup.
Old 12-07-2005, 11:45 AM
PREDATOR-Z's Avatar
So your setup will be tuned in SD mode.
Old 12-07-2005, 12:01 PM
91redchevy's Avatar
SD? Sorry i'm not up on some of the terms.
By the way stock cam specs are: int/ex 191/190 @ .050
.466/.457 lift
114 LSA
Old 12-07-2005, 12:07 PM
PREDATOR-Z's Avatar
SD means you will be tuning without a MAF (Speed Density), like in the old days.
Are you getting a MSD box to manage your coils?
Old 12-07-2005, 12:22 PM
91redchevy's Avatar
Yeah the edelbrock performer rpm manifold i ordered comes with the ignition control box.
I also am getting one of innovates LM-1 w/wide band o2 sensor to tune everything once
i get it going. I may be using a carb. but i want it to run as clean and efficient as i can.
I appreciate the help and patience.
Old 12-07-2005, 12:41 PM
PREDATOR-Z's Avatar
The TR 224/224, .563/.563 112lsa +4 is a heck of all around cam. That thing will be considered medium size in a 5.3.
Otherwise like I mentionned a VINCI/CRANE cam
Like:
062 (cam number on Vinci site)
DUR @ .004" 272*/280*
DUR @ .050" 210*/218*
LIFT .551 / .551
OVERLAP 52*
LSA 112*
Power range 1900>6000
Do you have the $$ to get a ported set of heads?
Old 12-07-2005, 01:00 PM
91redchevy's Avatar
I had considered either buying a set of heads or having mine worked. I only live about
30 minutes from Patriot Performance's shop here in Alabama. I thought about contacting
them about heads. I had thought bout just a mild cam swap where i could get the motor
in and tuned. Like i said this is my first LSx type motor so this is kind of a guinea pig.
Old 12-07-2005, 01:21 PM
tdrumm's Avatar
The Vinci 062 is a fun little cam in a 5.3.
Old 12-07-2005, 01:33 PM
91redchevy's Avatar
Thanks i'll check on that cam. Where did you get yours tdrumm?
Quick Reply: ls6 cam in a 5.3l
