LS6 Heads vs LS1 Heads
Old 12-07-2005, 06:27 PM
2sigmans's Avatar
Default LS6 Heads vs LS1 Heads
Can someone tell me what the gains would be going from stock LS1 heads to stock LS6 heads? My car is a 2000 C5 with an A4 tranny. My mods are LS6 intake, blackwing, Longtubes and a comp cam 218/224 on a 114. Car was tuned by More Performance and came in at 356 HP & 350 TQ. Just curious if it is worth the cost and labor. Thanks in advance!
Old 12-07-2005, 06:48 PM
vettenuts's Avatar
I would estimate 10-15 HP. I don't think it is worth the effort myself, unless the heads are really cheap. Considering all the heads now available, there are so many other options and a used set of LS6 heads is usually around $800.
Old 12-07-2005, 07:00 PM
hotrodrx7's Avatar
A ported LS1 head with an LS6 manifold will flow nearly as well as a ported LS6 head with the same manifold.
Old 12-07-2005, 07:01 PM
white2001s10's Avatar
I would get some 6 liter heads for $200 and port them for more gain than either of those choices.
Old 12-07-2005, 07:59 PM
2sigmans's Avatar
That's kind of what I thought, but wanted to hear from those that have gone before me. I don't really want to go with a huge CC runner, so I guess I'll save my money for some AFR 205's! Any other suggestions appreciated.
Old 12-07-2005, 08:20 PM
Well I'm confused now. I don't see where huge CC runners were mentioned in this thread. Am I missing something?
Old 12-07-2005, 08:54 PM
redtail2426's Avatar
yeah i dont what you guys are talkin about but ported ls6 heads will outperform ported ls1 heads any day.They have a better designed combustion chamber and redesigned intake runners.
Old 12-07-2005, 11:33 PM
2sigmans's Avatar
What I'm trying to say is if I don't go with a stock ls6 head, I don't want to go much larger on the port size. There are alot of heads on the market that have great flow #'s at the expense of low end torque. So if the gains from a stock LS6 head are not worth the cost and effort, then I think I'll hold off and save for some AFR 205's. Hope that clears up what I'm trying to say. I am still very open to other ideas.
Old 12-09-2005, 12:15 AM
transAm-98's Avatar
i recently went from stock 853 castings (98/98 heads) the some stock LS6 heads. it was a nice gain ALL THE WAY through through RPM's. i noticed a huge jump in mid range as soon as i drove it. thrugh my crappy exaust set up i went from 363 hp to 388. i never got it dynoed with the cut-outs open before. but with open cut-outs and LS6 heads i made 415hp 411tq. i got them dirt cheap on Ebay and i'm very pleased.
for as cheap as stock heads are i'd say go for it.
Old 12-09-2005, 09:13 AM
SUTTERERMAN85's Avatar
yea well the truck 6.0 heads have larger combustion chambers that lowers your cr. you would have to get them welded and then milled to get them to the same cr. unless you are talking about Ls2 heads then you are not going to be able to get those for $200. they are the same casting as the LS6 just without the sodium filled valves.
Old 12-09-2005, 03:47 PM
VTC_WS6's Avatar
Am I just not reading this right, or are people saying the LS6 heads aren't worth the swap from LS1 heads?? I always thought there was a good bit of power to be gained from the swap but nowI wonder if it's worth it for an LQ4 swap?
Old 12-09-2005, 03:54 PM
777's Avatar
A well ported ls1 head will outflow a NON-PORTED ls6 head. A ported ls6 head WILL outlfow a ported ls1 head by a good margin. Ls6 heads are worth the money, but if you aren't going to port them, then it is pointless. You can get your heads ported for less than a set of ls6 castings and make more power. Not a whole lot but more.
Old 12-09-2005, 04:01 PM
VTC_WS6's Avatar
Well put, thanks.
Who here is reccomended for a good port job on a set of LS6's? Or might it be more worth it to gust pick up a set of CnC'd heads already from someone like TEA or AFR etc?
Old 12-09-2005, 04:56 PM
2sigmans's Avatar
Hey thanks for the replies. I can get a new set of LS6 (243 castings) heads complete for around $750. Just trying to decide if I should jump on them or spend approximately twice that for a ported set of heads. Just questioning the horsepower to dollar ratio if ya know what I mean!
Old 12-09-2005, 05:11 PM
mountainbiker2's Avatar
Your graph will look like this if you get AFR 205 heads.
I added AFR heads and a Ported TB.
Before.
LS1 heads.
Comp cam 220/224 581 114
LS6 intake
Kooks headers
[IMG][/IMG]
Old 12-09-2005, 05:12 PM
CheeseNR7's Avatar
i picked up my ls6 heads for $600 assembled but i have seen them since then even lower near $500
Old 12-09-2005, 05:19 PM
just to give you an idea of what can be done with ls6 heads.I picked up a set of brand new ls6 heads complete with springs and valves for 500 bucks.Thats as cheap as they will get too.I then sent them to Bo White for porting.They now flow right at 300. cfm at .600 valve lift and thats with stock 2.00 valves and on a 3.900 fixture.They are only 229 cc on the intake which will still maintain good air speed and torque.On a 346 anything over probably 240 and it will hurt your initial hit of torque.I spent a total of 1250 bucks including shipping and packaging etc.In my opinion it was worth doing,they will performe extremely well for the money and they are true castings.unless you can get ls6 heads for less then 700 bucks then its not worth doing.for the price you can get some cncd heads.Unfortunatly Bo doesnt port anymore either,so you would have to find someone who does that kinda work and hope they know there stuff.300 cfm from a hand ported head with stock valves is pretty damn good.
Quick Reply: LS6 Heads vs LS1 Heads
