tang or on center
tang or on center
which is better. i have heard tang creates less backpressure, is that true. i have a t74 oncenter and have the opportunity to get a tang housing. should i do it, its a great deal. and will it fit right, going from one to the other. any input would be great.
Originally Posted by KAOS
lets keep it civil now. so if i had an oncenter t74 would a tang housing work and would i be able to tell a differecnce. like i said the deal i am getting is unbeatable if it will work.
The tangential will definitely make more power. I'd do it but realize that if the headers/manifolds are setup for on-center then the turbo housing may now hit something. If clearance is good the tangential housing is a lot more efficient. May not make a huge difference, but definitely will be a difference.
Jody
well the kit is in the process of being made so, i can do what ever i want but i just need to know if it will work. i mean i will the guts of an old on center t74 go into a tangetial housing any thoughts
