Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Tq monster: what would you build?
Old 12-07-2005, 09:03 PM
04LS1GTO's Avatar
Default Tq monster: what would you build?
ok I have a 84 chevy K10 with a weak 305. its a work truck so I am not worried about HP but I want a tq monster. what would you build? prefferably a small block on a 5k budget
I am thinking:
383 w roughly 10-1 compression
aluminum heads
comp cams extreme 4x4 218/226 .462/.480
edelbrock performer intake
speed demon carb
truck has headers and dual exaust
Old 12-07-2005, 09:24 PM
91Z28's Avatar
383 + small port heads and you'll have a tq monster.
Old 12-07-2005, 10:23 PM
Camaro396's Avatar
hell yes ^
Old 12-08-2005, 06:29 PM
Docspeed's Avatar
400 SBC with vortecs or fuelie heads would be nice.
Old 12-08-2005, 06:53 PM
04LS1GTO's Avatar
What heads would you run?
Old 12-09-2005, 12:43 AM
91Z28's Avatar
Vortecs would be good, but if you want aluminum heads for some good compression L98 Corvette heads.
http://purplesagetradingpost.com/sum...fo/heads1.html
http://chevyhiperformance.com/techarticles/41598/
There are a couple of decent sources for flow #s AND intake port sizes. Looks like for iron heads, the 882 castings would also work, I imagine used ones would be extremely cheap.
Old 12-09-2005, 10:49 AM
04LS1GTO's Avatar
looks like a set of vortec heads and do some cleaning up to them
Old 12-09-2005, 01:36 PM
rapid_rat's Avatar
Vortecs are a fine choice, but they are'nt aluminum. I would'nt be concerned about the material anyway, since the motor will be going into a work truck.
Old 12-09-2005, 02:03 PM
slow trap's Avatar
i've seen a 406 in a mag built with vortecs and the lunati .480/.480 make 500 ft/lbs tq.performer rpm air gap intake i think.
Old 12-09-2005, 02:36 PM
rapid_rat's Avatar
I'm assumeing the heads used in the article were ported? Stock vortecs perform better with a dual pattern. They like a little more duration on the exaust side due to its weaker flow in relation to the intake. That cam juiced picked out would compliment them nicely.
Old 12-09-2005, 05:27 PM
slow trap's Avatar
i can't remenber exactly but i'm pretty sure they were stock.i know the comp cam extreme energy .477/.480 cam is a good choice,but the 5oo ft/lbs is the most i've seen so far.personally i'd go with the extreme energy cam myself.
Old 12-09-2005, 10:29 PM
CTSV05's Avatar
Yep, the Vortecs are def. weak on the exhaust side.
I would be sure to run enough cam to fill the cylinders, but keep the duration in check, and I wouldn't run a regular performer intake, at least go with a higher level dual plane.
I always liked the Weiand Stealth for mild motors.
Old 12-10-2005, 05:07 AM
1994Z28Lt1's Avatar
regardless of what you do you will be happy because it wont take much to outperform the 305 thats in there
Old 12-13-2005, 03:17 PM
boostedinaz's Avatar
Are you only wanting to use a SBC? If not I would recommend a 472/500 Caddy motor. I have a buddy that has found many for about 300.00-500.00 running and they will make a ton of torque very low in the RPM range. Just a thought.
Old 12-21-2005, 07:21 PM
FASTONE's Avatar
Why don't you use the Edelbrock E-tec 170's as they are aluminum and flow better than L31 Vortecs plus have good springs and screw in studs and are under a grand. I would go with the 650 Demon if you are used to Holley carbs,I have a 750 and like it.You might want to try one of the Edelbrock carbs.
Old 12-21-2005, 09:02 PM
firefighter's Avatar
If I was gonna do it I would like to build a stroked 400ci ie 415 or 427ci
But you are talking BIG money. You could do something similar to what I'm building 383ci Eagle bottom end (all forged) and some E-tecs I went with the 200's trying to kill the tourque a lil (there is no weight in the back of a '65 C10) and the Holley Stealth Ram with a Comp XFI292. I was talking to my macineist who actually is a race shop (build all kinds of race cars and motors) he figures it'll be over 500/500 all day we'll dyno it early next year and see
Old 12-21-2005, 09:14 PM
seadoo's Avatar
I love trq monster engines... I love SBC's as well...
first trq monster build was a 355 w/ vortec's and a 212/220 cam... 450#'s
my new combo im building is...
• 406 inch, zero decked
• Edelbrock E-Tec 170, 64cc heads
• Lunati VooDoo 276 60104- 276/284, 233/241 at .050, .504"/.525" 110 LSA
• 1.6 Roller Rockers on the Intake, 1.5 Roller Rockers on the Exhaust
• 6” forged rods
• -18cc dished forged pistons
• .040 quench
• 10.1:1 Compression Ratio
• Edelbrock RPM Air-Gap
• Holley HP series 750cfm
• Hi Flow Mechanical Fuel Pump w/ ½ fuel lines
• Custom 1.625, 40” primary length, 2.5” collector headers
• Pypes 2.5” Cross Flow system
Old 12-27-2005, 02:38 AM
JPMuscle's Avatar
540 Bbc
Old 12-27-2005, 10:42 AM
Now that would make some tourqe
Old 12-27-2005, 12:47 PM
foxspy's Avatar
I have a fuel injected 502 BBC that would go nice in the K10. It put down 619ft/lbs of torque on a chasis dyno.
Click here for specs.
Quick Reply: Tq monster: what would you build?
