Bearing failure.. cause?
the crank is a 4340 steel unit and its fine, no scoring or anyhting. was using 10w-30 oil, stock powdered metal rods, H bearings. rods #3, 4, 5. any ideas?
Hmm, that almost looks like the crank isn't true from what I can see in the pics. Might be a good idea to maybe have a shop look at the crank and see if it is indeed off. If it is then maybe polishing it might bring it back. As for clearnances where were your clearances set at?
