M6 and 12 bolt =No No?
Old 12-07-2005, 10:49 PM
TAwananbe's Avatar
Default M6 and 12 bolt =No No?
Purchased the car like this and a lot of people wonder why I have a 12 bolt rear?
Moser 12 bolt btw.....
Why is a 12 bolt so bad w and M6? I know im losing some Hp cause its so heavy and all but isnt it a much stronger unit?
Old 12-08-2005, 02:03 AM
Slow00ls1T/a's Avatar
12 Bolt isnt bad at all some since you have a m6 which are harder on rears they say a 9' is best for m6s since the rears take so much of a shock on launch
Old 12-08-2005, 04:38 AM
67camaro's Avatar
why not? as long as that weak *** 10 bolt is nowhere to be seen, you're better off.
Old 12-08-2005, 05:07 AM
EPP
EPP's Avatar
The Moser 12 bolt is indeed an excellent rear-end for your car. Whoever told you that it should have the 10 bolt does not have much experience with them. Bob
Old 12-08-2005, 12:37 PM
TAwananbe's Avatar
Thanks, any one else?
Old 12-08-2005, 01:52 PM
CW00BlackTA's Avatar
It's a lot stronger than the stock unit. Be thankful it's there--saved you a couple grand having to do it yourself.
Old 12-08-2005, 02:12 PM
STRIPSTAR's Avatar
You can gladly trade for my mint low mile 10 bolt if you wish.
Old 12-08-2005, 04:31 PM
GTObsessor's Avatar
What he said and the guy above me said
Old 12-08-2005, 04:54 PM
BrandonDrecksage's Avatar
they're probably just shocked that it doesn' have the stock rear.
Old 12-08-2005, 08:18 PM
02 Camaro SS's Avatar
Whoever is wondering why you have a 12 bolt must be doing so since you don't have a 9". The 9" is about as close to indestructible as you can get so some people say as a rule of thumb that a m6 should get a 9" and an a4 should get a 12 bolt. Nonetheless, a 12 bolt is a HUGE upgrade from the stock 10 bolt and plenty of people have run 500+ hp with one without having it crap out.
Old 12-09-2005, 01:19 AM
lsevenl's Avatar
definitely be thankful you have an upgraded rear end It's a priority once you start running the m6 in low ETs!
Old 12-09-2005, 01:48 AM
bmfcamaro's Avatar
i was pulling 1.6 60' with 5500 to 6000 rpm clutch dumps. no probs here.
Old 12-09-2005, 12:43 PM
TNTramair's Avatar
must be freakin nice!!!!!
Old 12-10-2005, 11:06 AM
TAwananbe's Avatar
5-6K????? on a manual?
can you teach me how to do this?
I feel like im going to break the car doing 2k or so and easing into it.
I know, I know.....the car is still damm fast even without good 60s.......1.9s to be exact.
i couldnt imagine pulling a 1.6 and lowering my car into the low elevens or 10s on spray......
im just to afraid to break a 2-3k dollar piece on the car.
Old 12-10-2005, 11:32 AM
bmfcamaro's Avatar
bad thing is that it only got me a 13.1 knock retard is a bitch. trying to get that fixed. some tuning issues and 98 knock sensors. hopefully join you in the 11 second club this wed
Old 12-10-2005, 11:35 AM
bmfcamaro's Avatar
just get a 12 bolt or 9" whatever, nice clutch (i have stage 4 spec), and some et streets. i didnt just go out and do it. i increased on each run. start around 4000 to get the hang of it. when i get it tuned nicely it should be a whole lot a fun
Old 12-10-2005, 11:51 AM
TNTramair's Avatar
what a blast my car should be to drive when i finally get a 12 bolt in there. i still cant imagine putting my car through the torture of 6krpm dumps...just the thought alone make me cringe, but if thats what its gonna take to get me into the 10;s...than im all for it...all that cringing will go away when i get that time slip..
Old 12-10-2005, 11:57 AM
bmfcamaro's Avatar
thats right
Old 12-10-2005, 12:35 PM
LS1TECH Sponsor
Jonathan@Tick's Avatar
1. Push clutch in
2. place tranny in 1st gear
3. Rev engine to 6000 rpms
4. Slide foot off clutch
5. Hang on
Old 12-10-2005, 04:55 PM
TroubledWine3's Avatar
Sidestep that bitch and hold on.
Quick Reply: M6 and 12 bolt =No No?
