really confused!! on a head and cam setup
Old 12-08-2005, 02:14 AM
TXZ28LS1's Avatar
Default really confused!! on a head and cam setup
hey guys. ive done all the searches i possible can do. i really need your guys help on doin a bad a$$ head and cam setup for my daily driver street a4. full bolt ons. the stall im looking at is a 3200 stall. its all street no track. not trying to rip 10's. should i run:
mti 2e heads w/ x1 (230/2270 or g1 (228/232)
afr 205 w/ g5x1 or
afr 205 224/581/114
im lookin at these setups. i really need lots of feedback on which route would be best and make sure i do it right the first time and not waste money. i would like to make atleast 415rhwp....thanks...
Old 12-08-2005, 02:58 AM
AncientRgn's Avatar
If you got the money to do it, I would personally go with the AFR heads and the 228/232 cam or quite possibly a tad bigger (230/232?). Definately get some 3:73 gears for the A4. The G5x1 cam IMO is overkill for a daily driver.
Old 12-08-2005, 06:34 AM
PREDATOR-Z's Avatar
G5X1
228/232, .588/.574 -112/114 lsa
By no means overkill. But as I mentionned in the PM's do you bolt ons first.
Old 12-08-2005, 10:21 AM
TXZ28LS1's Avatar
definitely. thanks alot predator. you got mad knowledge. i mean at first i really wanted to just be safe and run afr and 224 cam just to be safe. but i hear lots of people saying go bigger. if my car is all for street and track would i need to go bigger? or would i be happy with it.
Old 12-08-2005, 11:02 AM
PREDATOR-Z's Avatar
FM 11 >228/230 .576"/.595" 112/114 lsa
G5X1 >228/232, .588/.574 -112/114 lsa
MTI G1 >228/232, .588/.575 113 lsa
All of these cams are in the same power range, G5X1 and MTI on Comp Cam lobes and Futral on Cam Motion.
Old 12-08-2005, 08:19 PM
redhotz28's Avatar
with the afr's will the the pistons need to be notched?
Old 12-08-2005, 08:27 PM
AncientRgn's Avatar
Whoops! My appologies. I got those "X" cams mixed up.
Old 12-08-2005, 08:40 PM
Louis's Avatar
Id like to update that the X1 exhaust is now .590 lift.
I replied to your email
Old 12-08-2005, 10:10 PM
WILWAXU's Avatar
Nothing but good things to say about the "budget" MTI Stage 2E's & X1 setup.
Drive my car everyday, accross country and everywhere in between... and, It's ran 10's
