Gears & Axles - How to tell what ratio gear in rear end?
Stephen Griner
12-08-2005, 11:18 AM
How do you tell what ratio gear set is in a rear end if you DON'T have the cars option code(i.e. gu2, gu5) Rear end is not in the car. I didnt want to pop the cover and try and count the teeth. So if anyone knows if there is a number or something stamped on it or something?
Thanks,
Stephen
2001NBMZ28
12-08-2005, 11:26 AM
Try www.f-body.org/gears/
DBUS6
12-08-2005, 11:56 AM
You will need to jack-up the rearend "safely" (block front tires) on jack-stands. Put the tranny in neutral and mark the driveshaft and tire/wheel. Rotate the wheel one full turn while counting the driveshaft rotations. ie: if the driveshaft turns "almost" 3 1/2 then you probably have a 3.42 ratio
Pretty simple really
Good luck and have FUN
Stephen Griner
12-08-2005, 02:01 PM
If you spin the rotor once, the drive shaft yoke spins twice. ??
Stephen
