Will a 27" tire be enough when I spray
I want to get some tires on my M6 stock internal bottle fed TA. Like I said, it's SI car with a 100 shot, 4.11's, and a 6400 rev limiter (which I can bump a little more if needed but I would rather not). I want a tire that won't hurt me too much when I just run motor, but that will get me through the traps without banging the limiter.
I figured a 27" tire would do the best job? What do y'all think?
Originally Posted by mike c.
turn up your rev limiter. i have spray a 150 shot on a h&c car w/26'' tires. i trap at 134mph in the 4th mi still in 4th grar. i even cut 1.3 60's on the spray m6 car.
I went to the track yesterday and trapped 115 NA on 26" street tires, so I'm pretty much at the limit of my current setup.
Dan
Originally Posted by SLPSS99
Hope you have some better Valve Springs/Pushrods if you plan on pulling that thing to 6400+ RPM and your car is stock internals
Dan
Dan
