Custom camshaft for n/a and nitrous power.
Old 12-09-2005, 09:12 AM
CraZee ZO6's Avatar
Default Custom camshaft for n/a and nitrous power.
Hey.
2003 zo6. Stock LS6 (347ci). Intake, exhaust, TPIS Longtubes, off road X.
I want to spec out a custom cam that will make n/a power and make nasty power on spray.
So lets hear it.
Thanks.
Old 12-09-2005, 09:41 AM
PREDATOR-Z's Avatar
ED,
Where are you?
Crazee, you need to let us know what power range you wish to use, smog legal or not, lopey or not etc...
Old 12-09-2005, 10:40 AM
Ed Curtis's Avatar
Talking
Originally Posted by PREDATOR-Z
ED,
Where are you?
Hey Pred,
You know I can't do much on this site.
On a more "Hardcore" site, I can...
Ed
Old 12-09-2005, 11:49 AM
PREDATOR-Z's Avatar
Old 12-09-2005, 10:34 PM
CraZee ZO6's Avatar
ED,
Where are you?
LOPEY is cool. Not a daily driver. But I do drive it on the street.
Emissions are not a problem.
I want POWER.
Old 12-09-2005, 11:33 PM
CUJO98TA's Avatar
Default Cam
What about 236/240 .602/.609 LSA 113 +2
Jeff
Old 12-10-2005, 02:30 AM
Restricted User
CAT3's Avatar
Crazee, take it to a pm to EDC, Ed hooked my cam up. I wanted the same thing, but I have other supporting mods which I am sure make a difference, and I really have no clue as to the intricate specs of the cam other than:
231/242
.637/.622
114lsa
Will maximize up to 300shot of Nitrous.
How much nitrous you plan on spraying, weight, head flow and all that jazz plays into. A simple pm might help you out a lot.
Charlie
Old 12-10-2005, 07:13 AM
Z06 Steve's Avatar
what rear gears? need to match with right cam.difference between a dyno queen or getting spanked at the track.
Old 12-10-2005, 07:27 AM
itchygomey98's Avatar
To be honest, I wouldn't do a cam at all without headers.
Old 12-10-2005, 03:48 PM
CraZee ZO6's Avatar
I havfe TPIS longtubes.
Right now 3.42 gears, but I can change that later.
Old 12-10-2005, 07:47 PM
WhiteLTone's Avatar
predator do you think i'd run into ptv clearance w/ a set of diamond -2cc pistons, and a set of milled stock ls1 heads- with the cam u mentioned above?
Old 12-10-2005, 10:51 PM
PREDATOR-Z's Avatar
You mean 236/240 .602/.609 LSA 113 +2 ??
Depends on how much mill and what gasket.
Old 12-11-2005, 03:17 AM
WhiteLTone's Avatar
actually my bad had originally thought u had posted the specs on this cam, but as i re-read the thread i noticed it was CAT3, i was infering about this cam:
231/242
.637/.622
114lsa
sorry for the mis-understanding.
Old 12-11-2005, 05:23 AM
Z06 Steve's Avatar
I would do a medium size cam because of the stock heads.my 224/228 is great in my book but dont know if it is spray friendly.
Old 12-11-2005, 08:16 AM
Ed Curtis's Avatar
Question
231/242
.637/.622
114lsa
That's one of mine... Which piston are you running? Makes a difference.
Just for my own curiousity, why would you want a custom camshaft designed for someone elses combination?
Ed
