how in the hell??
you might be able to put two of the bolts in the flexplate and slide a long pry bar in there and jam it on the bottem of the car somewhere to keep it from turning. If you have an impact gun you might get it to break loose with that.
what i did is get some vise grips and lock it down tight on the flex plate but where the handle is against something tought like the floor pan.. and now the motor wont turn as your pryin on that bolt..it would be easier to use a impact..i just dono if you can fit it between the motor and the fans
what I did was take the handle from my floor jack (both pieces) and slide that in from the top. Then I just put a little muscle into it and I broke it free. I love that concept called leverage! Now if I could only find a bolt long enough to get my new pulley started!
I wouldn't recommend using an impact. If you are dead set on using one, I would only use it to take it off and not to put it back on. I have read a lot of horror stories of people stripping crank threads with an impact.
