Am I missing anything?
Old 12-09-2005, 03:34 PM
BLUE99T/A's Avatar
Default Am I missing anything?
One week from monday I am installing my cam. I just need you cam guru's to glance over my list of parts that I have in front of me, just in case I forgot something. Thanks.
cam
918's
p/r's
retainers
timing chain
oil pump+O ring
rockers
valve locks
valve seals
crank bolt
2water p gaskets
front seal
timing cov gasket
spring tool
pulley puller
Old 12-09-2005, 03:36 PM
Derek98z's Avatar
it's up to you, but I use cam assembly lube and you need loctite for some of the bolts. Do you have the puller for the pulley?
Old 12-09-2005, 03:54 PM
BLUE99T/A's Avatar
Thanks, Derek.
