Running Rich on the pass. side
Running Lean on the pass. side
Swapped my spark plugs today and all my plugs on the passenger side came out looking like I was running lean on that side. Driver's side looked rich/normal.
Now the only thing I can think of that might be causing this is that when I did my cam install and dropped a pass. side lifter... while I had the head off ... I cleaned the carbon off the faces of the pistons. Could that small amount of volume difference be causing the leaner conditions?
