Any write up for rod bolt install?
Old 12-09-2005, 09:50 PM
SSU's Drunk Typing Whore
Lithium's Avatar
Default Any write up for rod bolt install?
I dropped my pick up tube bolt in the oil pan as well.
So I figure that I am going to have to install these Katech rod bolts first.
So I drop the K memeber? then the oil pan?
Will I have to move the engine in any way to do this with it still in the car?
Help!
Old 12-09-2005, 10:10 PM
Ferocity02's Avatar
Well the engine is attached to the k-member, so if you are going to drop the k-member then you will need to support the motor somehow. I am intertested to see if this can be done without removing the k-member.
Old 12-09-2005, 10:19 PM
Lithium's Avatar
Yeah I am pretty sure that you have to hoist (sp?) the engine up some.
Just seems really intimidating to me.
