another exhaust.....
im about tired of my exhaust hitting the rearend when going over bumps. is their any way to adjust it since it is welded up? if not i think im going to get another exhaust, what would you guys reccamend for a good price? i still want it to be loud and deep, but in a way i want something different.
LS1Tech Administrator
Received 1,471 Likes
It's probably hitting that upper panhard bar where the I-pipe goes over the axle. That's a common issue if the catback wasn't adjusted properly when installed.
You might be able to modify the hanger to pick the pipe up a bit and clear that bar, if that is where it's hitting.....
it it touching that bar, but it only does it when the rearend drops way down. im going to try and play with it some and see if can get it to work. but if not ima just get a new catback. what catbacks do ya reccamend for a pretty good price?
you could modify both of your hangers. it probably moves around a good amount. what you want to do is get the hangers so they barely move at all in the mounts. this will keep things from banging around.
