Has Anyone Seen This?
I came across a set of LPE cnc'd heads with the rocker stud perch ripped off on the intake side. Has anyone seen this or heard of it, and if you did has anyone been successful in fixing it? I'd hate to pass on these if they are fixable. Any help would be appreciated.
If the rocker boss is gone or broken very bad on the intake side, it is from excessive porting and possibly high spring pressure. I have seen other heads such as GM's splayed valve (baby big block heads for small blocks) do this from to much porting and high pressures. You can reweld the boss, but I think that it better be a real good deal to have to go through the trouble.
