Advanced Engineering Tech - Measuring Bearing Clearances - Help
Dutchesscamaro
12-11-2005, 03:32 PM
When I measure main bearing clearances with a bore dial indicator I am making contact between the indicator and the bearing surface. As I rock the bore dial indicator to get the highest reading it "marks" the bearing surface.
Is this detrimental to the bearing?
Am I doing something wrong?
Is there a technique to avoid this marking of the bearing surface?
Thanks
Bob
SLED28
12-11-2005, 04:07 PM
That is normal, it is more a shadow then anything
Dutchesscamaro
12-11-2005, 04:10 PM
ok....but it doesn't wipe off. So I must be marring the surface.
Again... normal?
SLED28
12-11-2005, 04:18 PM
you won't feel it with your fingernail though, the bearing is pretty hard...
DrivenWS6
12-11-2005, 08:20 PM
Or a T-gauge and micrometer. Its a lot more time consuming but its also a lot more accurate.
Keep the dial bore gauge, if it is graduated in .0001"
My Mitutoyos have different size spacers, so if you can, use a thinner spacer which will preload less. Still the small marks are not a problem if you use the tool correctly.
Zero the dial bore to a calibrated mike and off you go... Check at 0, 45, 90 and 270 degrees.
No plastigauge or T gauge is going to show you tenths.
Old SStroker
12-11-2005, 09:58 PM
It depends. Set a bore gage and have 5 people measure a hole. Then give 5 people a T-gage and the same micrometer used to set the bore gage and have them measure the same hole. I'll bet the range of sizes with the T-Gage is 2-3 times the range of the bore gage measurement. As in many things, "feel" is important.
My $.02
Ben R
12-11-2005, 10:09 PM
That is normal. Don't worry about it.
Ferocity02
12-11-2005, 10:37 PM
to measure clearence, do you just subtract the bearing bore diameter by the crank journal diameter then divide by two? I though you assembled the crank into the main bearings then used a feeler gauge between the bearing and the journal. Then again, I haven't built a motor before. Thanks!
I agree with OldSS 200%, feel is important and a lot of people don't have it.
Here is the easiest way for a novice. IMO
NOTE: I use the word 'mike' as an abbreviation for micrometer
1) Use a mike with a ratcheting or friction thimble in the end of it. NEVER overtighten the mike, always use the thimble.
2) Using a standard (2" or 3" that came with the mike), check that the mike is calibrated. This is assuming that everything is clean. Don't use rags with lint and clean the ends of the standard and mike by lightly wiping against your skin.
Adjust if necessary and re-check that the mike zeros properly, by measuring the standard and wiggling the standard a little as you get close to tight (thimble only). Do this without looking at the mike graduations. Many people try to tighten until it reads what they want it to read. Do this a few times, to get the feel for the mike and check that it is zeroed each time. With a bit of practice, you will get the feel and your measurements will be consistent.
Caution: Before taking a mike to a crank journal, you may want to try the next part on the snout of the crank so that you don't scratch the journals while you get the feel for the mike.
3) Now mike the (clean) main in question. Once again, when you get close to tight, rock the mike back and forth lightly and wiggle lightly. Note: You are rocking to try and find the biggest point or actual diameter. You are wiggling to make sure that the mike is square to the journal. Remember all of this is done with a VERY light touch while slowly tightening the mike with the thimble. If the mike binds at all, gently loosen and or wiggle the mike, or you stand a chance of scratching the journal.
4) Once you have the mike on the actual diameter of the journal, then gently tighten the lock, and then slide the mike off.
5) Check that the measurement is within the specs of the journal. If not, then ither you measured wrong, or the mike is not calibrated or the crank is out of spec.
In any case, what you are really looking for is the clearance, so if the crank is a little on the high or low side, but still within spec, then you should be good to go.
6) With the mike still locked, try to slide it onto the journal. When it gets a bit light, wiggle and slide. If it gets real tight, then stop and go back to step 2. It should slide on with just a small amount of resistance.
7) Put a rag over the C section of the mike and clamp it VERY lightly in a bench vise. Clamp only enough that it doesn't fall out.
8) Assemble your dial bore gauge using the proper tip and spacers.
9) Place the assembled gauge in the mike starting with the plunger end first and then the fixed end. This can be tricky at first. Once both ends are resting against the mike surfaces, center one end with your thumb and forefinger and gently rock the other end slightly up and down and then left and right. You are looking for the smallest reading on the dial. (The furthest reading in a clockwise direction on my Mitutoyos.)
10) Read the dial and make a note of how far off zero is from the needle and in which direction. Remove the gauge from the mike and rotate the dial by the amount noted and in the correct direction. Repeat step 9 until the dial reads zero. Also make a note of where the small dial is (usually marked 1 to 5 with a smaller needle), and then lock down the dial clamp.
11) Now you can assemble a main with bearings and check it at the four postions.
I like to start with the rear main and work forward. This method also gives you the actual clearance, which is what you are really looking for.
Sorry for being long winded, but I thought that some might find it interesting... :chug:
On another note, I do a bit of chamfering on the mains and caps so as to not shave the bearings, but that is a subject for another day.
Mike454SS
12-11-2005, 11:12 PM
guys, it's a mic (as in micrometer), not a mike
NO-OPTION-2002
12-12-2005, 01:51 AM
Not trying to get to "picky", but mot standards are set up to be used at ~68*F.
The heat from your hands will "expand" the standard. I know this is minimal, but if we are talking precision, lets talk precision. :)
Ferocity02
12-12-2005, 03:33 AM
I thought the lint from the towels was picky... I guess I should wait until spring to check my bearing clearances... ;)
A valid question nonetheless.You don't divide by 2.
Thanks mic :) (Just kidding) :jest:
Not to mention controlled humidity, etc. Bottom line is that everything should be at the SAME temp, and not recommended that you measure in your garage at -40F. You could be off by 50 millionths or so... :bang: not to mention frost bite :cry:
I'm impressed that anyone even read my long winded BS...
Seriously tho...
I am sure that there is plenty of good reading material that describes clean rooms, calibration and measuring techniques, etc. Maybe some could mention good books on the subject for those who are just starting out.
One tip for the novice DIY crowd is ...
In selecting a shop to do your machine work (boring, honing, etc) you should show up with your gages, and ask them to check your stuff. If their results are not the same as yours, whip out the gages and compare on site. Either you are them are in error.
If it's them, then MAYBE take your stuff elsewhere. In any case, the shop now knows that you will be checking and they will probably try to do a better job.
I had a dispute with a shop many years ago regarding piston pin clearance. It called for .0008" (or 8 tenths).
After I measured and they measured and we all re-measured and argued (in a somewhat friendly way) , I whipped out a .0015 feeler and slid it in between the parts in question. That ended the argument. They fixed the problem and since that day, I NEVER had a dispute with them.
Bear in mind that diplomacy is the the best route and that MOST machinists (in any field) are a proud bunch and don't like to be proven wrong.
On the other hand, some shops are just NOT capable of producing really good work, due to bad equipment and/or operators.
Am I :offtopic: :bang:
Old SStroker
12-12-2005, 07:46 AM
Most standards come with a plastic (insulating) section for you to hold onto.
Whatever the temp of your engine building room, the measuring tools should be "soaked" to the same temp by being in that room for a while. I you are antsy about a few degrees, put the mics (or Mikes :) ) in a pan of room temp solvent between times you use them.
Someone should put up a video showing how they do all this.
I have the video and editing stuff, but not the time at this moment.
'JustDreamin'
12-12-2005, 08:28 AM
You guys have made a bunch of excellent points.
Instructions on how to properly use a micrometer & associated measuring tools are well written, Kudo's to the writer.
Temperature is certainly a potential issue. Measuring the parts at the shop is a good suggestion. If they measured the parts hot (from machining) , then you pick them up 3 days later and measure the parts in your garage at 20 degrees F, you certainly could have a difference of measurement. Measuring them at the time of pickup may be time consuming but is certainly a useful thing if you're building a high precision engine (if you're just slapping together a rebuild of a 350 SBC for Joe's beater, then it probably isn't worth all that effort).
But be prepared for your measurements and their measurements to differ. Even using the same gage mutliple operators are likely to get multiple measurements. Throw 2 sets of gauges in the mix and you'll definitely have differing measurements.
In the manufacturing world (or at least the chunk I work in), many customer's require Gauge R & R studies (which is Gauge Repeatability and Reproducibility). Basically its a statistical study done with 1 gauge and multiple operators (minimum of 2) and multiple parts (typically 10 pieces which are numbered) with each operator measuring the same feature (on all parts) multiple times (often 3 to 5 times). Ends up being a lot of time spend measuring parts. Enter all the data into a computer program to do the statistical analysis (trust me, you don't want to calculate that by hand) and you get an idea of how good your gauging system and your operators are.
Nothing like making a simple act (measuring a part) overly complicated, right?
'JustDreamin'
FWIW I edited my first post to get rid of some typos and explain the word 'mike'
I rattled it off late last night, so please forgive my mistakes. Please everyone feel free to add or correct anything as needed.
A lot of machinists including engine builders are reluctant to share stuff. :devil:
Also, someone could explain expansion of metals and how say 10F change in temp will affect the actual meaured size of a part. (I'm too lazy to look it up) :bang:
MadBill
12-12-2005, 09:10 AM
Speaking of temperature effects, I calculated this three times because it seems surprisingly high, but with a coefficient of thermal expansion of 7 parts per million per degree F., a 3" main journal (OK, maybe no one here's doing Pontiacs but it's a nice round number...), warmed from the previously mentioned minus 40 F. to plus 70 F., would expand 7 x 3 x 110 = 2310/1,000,000 or over two thousandths of an inch! Proportionally, a 2 tenths change would result from a mere 10 degree difference, so the combination of a cool crank and a micrometer clenched in the hot sweaty fist of the builder is of much more than just theoretical concern...
Old SStroker
12-12-2005, 10:53 AM
Temp is always a concern. Currently we are grinding bearing rollers to .7500/.7497. We'd like all the tolerance so parts, gages and room air are all within about 3F. That's about 15-16 millionths, isn't it Bill?
If we get a crank delivered by UPS it's usually just about the outside temp (25F today), so it has to soak in the shop air for 8 hours or more to get to a temp to measure it. I'm not sure I'd want to measure one @ -40F!
Hot honing a block presents a measurement challenge. Sure, with 6.8 millionths/in/F for cast iron, a 4.030 bore hot-honed @ 230F should be about .0038 bigger than it will be at 70F room temp. The bore gage is about 70F before you put it in the hole, but heat transfer thru the gage tips into the bore gage happens quickly. I suppose you could have a setting ring to recheck the bore gage thermal growth as soon as you pulled it out of the hot bore, but it still seems like a challenge to get exact size.
mdrew
12-12-2005, 11:06 AM
Couldn’t agree more with the “feel” statements. I suggest playing with standards for a while prior to measuring a journal. Especially as tight as clearances are getting anymore.
Also, make damn sure whatever your measuring is clean. Very clean. I like to keep a few cans of electric motor cleaner around just for this.
The marks your bore gauge is leaving on the bearings is normal, no matter how gentle you are. If your not leaving them on H or coated bearings, your doing something wrong. I usually take scotch bright to my bearings, so the marks get removed anyway.
'JustDreamin'
12-12-2005, 12:44 PM
Just for giggles, I looked up what the accepted linear expansion rates are for a couple of materials. #'s are from Machinery's Handbook, 17th edition (1964, but some things don't change that much)
Steel: 0.00000633 inch expansion per inch per degree F
Cast Iron: 0.00000655 inch expansion per inch per degree F
Aluminum: 0.00001244 inch expansion per inch per degree F
Makes me think that an aluminum block is going to move around a bunch at temperature. For example a 9.240" deck height at room temperature (70°F) is all of a sudden going to be 0.015" taller at 200°F. And shorter at lower temperatures (luckily not enough to eat up the quench space since the reduction in height is about .012" at -30°F).
All the mixed materials involved these days really makes one think hard about building an engine. Have to decide exactly what clearances are needed, especially considering the materials involved and the operating environment they will see. Makes something that seems trivial (yeah, I've got a balanced & blueprinted motor....) a lot more tricky when you start really looking hard at it from an engineering standpoint.
'JustDreamin'
'JustDreamin'
Which brings up another old discussuion about quench and expansion. This is why many lean towards the tight side (.030"), depending on ambient temps.
Also, steel or iron mains on an aluminum block. What is happening there?
MadBill
12-12-2005, 01:22 PM
Yes, I brought up the quench/squish thing re aluminum blocks in another ls1 thread. Much of the lore re how tight you can run is from iron SBC block experiences; you should be able to safely run at least 0.006" less in an aluminum block.
Speaking again of expansion (Holy thread hijack, Batman!), a prestigious US Porsche tuner a few years ago was going through valve lash loops on an air-cooled 911 mill on the dyno and gaining power each time they closed them down. They knocked off for lunch and when they returned, couldn't get the engine started. Eventually discovered there was no compression, due to negative cold lash...
Old SStroker
12-12-2005, 01:43 PM
'JustDreamin'
Don't forget the steel crank throw, steel rods plus aluminum piston compression height are going to also grow to reduce that .015 by about half. Same thing going colder/shorter. Hence MB's -.006 quench.
Now that we are totally off topic, does anybody remember what a mike is? :devil:
We must of taken a wrong turn in Albuquerque... :eek2:
'JustDreamin'
12-12-2005, 02:10 PM
I knew we shouldn't have let that wascally wabbit drive!!!! He always misses the left at Albuquerque.
I don't know that we're terribly off topic. But I'm not sure if the original question got answered fully.
'JustDreamin'
Ferocity02
12-12-2005, 03:12 PM
Back to the main topic... Lets say I found that one of my mains has a clearance of .0012", which from what I've read would be an acceptable tolerance... Does this mean that .0012" is the clearance between the crank journal and the bearing surface on both sides... meaning there is actually .0006" of spacing between the journal surface and the bearing surface?
Also, LME said that they shoot for a clearance of .0007" to .0021" on their main bearings. Is anywhere in that range acceptable, or will .0007" have a lot of friction and .0021" have little oil pressure? I assume the middle of the range like .0014" would be a great clearance to have?
Final question, are the goal clearances on the main AND rod bearings the same? Thanks!
That is correct. 6 tenths per side for a total of 1.2 thou...
Clearances would depend on your application. Give details...
I will say that I would never run 7 tenths on anything, but that's just me.
Ferocity02
12-12-2005, 06:00 PM
Thanks for the help! I agree that 7 tenths seems like practically no space at all, even for a thin layer of oil.
My application is a NA street motor, aiming for around 550rwhp. There is a slight chance of a little N20, but that won't be for awhile. I am looking for reliability, long life, and good oil pressure(40+psi), and ofcourse good power. Basically, I think halfway in between acceptably tight and acceptably loose, if that makes sense. I would prefer the motor be built tighter than looser.
Bryan@LME
12-12-2005, 11:18 PM
If we are talking cast iron block for an LS1, we generally set up the mains at
.0024"- .0027". This will give you great oil pressure and durability. On aluminum we like the mains to be a bit tighter.
I would not run the mains as tight as .0007".
If you have ever checked a stock aluminum LS1. You may be suprised how tight they will run.
Beast96Z
12-12-2005, 11:44 PM
My application is a NA street motor, aiming for around 550rwhp. There is a slight chance of a little N20, but that won't be for awhile. I am looking for reliability, long life, and good oil pressure(40+psi), and ofcourse good power. Basically, I think halfway in between acceptably tight and acceptably loose, if that makes sense. I would prefer the motor be built tighter than looser.FWIW, with the crank that was in that motor, they showed .0024" on the main bearings and .0022" on the rod bearings. Depending on how close the Eagle crank is in diameter to the Lunati, I'd look for the clearence to be similar with the same bearings. :)
Ferocity02
12-13-2005, 01:11 AM
Do you still have the dimensions for the crank journals on your Lunati crank? If you do, then I can mic my crank journals and do some math using your clearances to find mine. That would save lots of time and money on tools.
SILVERZZ28
12-26-2005, 10:45 PM
My $.02very true! :chug:
Gary Z
09-25-2008, 06:01 PM
Resurrecting a very old thread because I appreciate good information. I am a machine shop class dropout who knows how elusive accurate measurements can be. rjw's micrometer lesson is excellent.
blackz93
09-29-2008, 02:42 AM
The avatar above your post made it A OK to bump this from the dead! :)
The Dark Side of Wil
10-01-2008, 01:46 PM
Now imagine what the differential expansion does for clamp loads on steel fasteners holding aluminum parts together.
Now imagine that the torque + angle sequence for those fasteners had been determined by GM engineers after taking thermal expansion into account.
What temp is the engine when the fasteners are tightened? Yours was at the same temp, right? ...right? What? You assembled your aluminum engine in a 30degree garage? Wooops....
ChiTownHustler
03-11-2009, 10:03 PM
Inquiring minds want to know?
