Sea Foam
Sea Foam
How long do I let this stuff sit before I start the engine again and how soon after I do the sea foam in the brake booster hose do I need to change the oil? i have searched this topic but these answers are still a little unclear.
The can I think states to let it sit for about 15 minutes. You should at least let it sit for this 15 minutes. Some people do 2 or more hours and some even overnight.
I would do a hour. Then as others say, start it up and watch the smoke show. Then run it with some good WOT runs. Then bring it home and change the oil.
But you don't have to do it exactly like that, of course.
They will not damage the plugs. I normally just put in the first 2/3 of the bottle in slowly into the PCV inlet on the intake then the last 1/3 dump it in to attempt to get the engine to flood itself and turnoff. Sometimes it doesnt so I got my wife in there to cut it off just as I dump the last 1/3. I let it sit overnight and then start it up next morning and it starts right up and smokes up the entire front of the house like I started up 10 fog machines for a disco club.
All the times Ive done it after that have been very light because its already clean. The first time will show you some crazy amounts of smoke, I mean never ending, but it will end after a 10min drive. Just be careful and wait till it stops smoking bad so you dont blind the driver behind you or drive down some dead road.
Dixit
Dixit
