Introductions & Greetings - Hi All..
View Full Version : Hi All..
GeneralIII
12-12-2005, 09:45 AM
Hi everyone. Building a new toy that I'm guessing no one else here has :newbie: :newbie: . I am building (from scratch) an all new aluminum Airboat with a LS1 engine. I will be welding up the hull this winter. Everything is lightweight aluminum, so I figured, why put a heavy cast iron cylinder and head engine on it? The Airboat people keep saying how much better it is with saving 75 lbs. with aluminum heads. I figured I would use newer technology (get away from carburators with chokes) and even save more weight from hanging up off the hull. I just bought a LS1 long block and am looking for some parts for it. I can't wait to start on this project.--Bruce
GeneralIII
12-12-2005, 09:46 AM
Hi everyone. Building a new toy that I'm guessing no one else here has. I am building (from scratch) an all new aluminum Airboat with a LS1 engine. I will be welding up the hull this winter. Everything is lightweight aluminum, so I figured, why put a heavy cast iron cylinder and head engine on it? The Airboat people keep saying how much better it is with saving 75 lbs. with aluminum heads. I figured I would use newer technology (get away from carburators with chokes) and even save more weight from hanging up off the hull. I just bought a LS1 long block and am looking for some parts for it. I can't wait to start on this project.--Bruce
Transcoupled
12-12-2005, 10:08 AM
Sound good! Well good luck to you and there should be plenty of parts you for you to gather in the for sale sections!
