Best way to remove orange peel
Old 12-13-2005, 01:09 AM
tmister's Avatar
Default Best way to remove orange peel
Best way to remove orange peel on black paint?
Old 12-13-2005, 01:44 AM
stryker14's Avatar
best way and only way would be to wetsand it with 1,500 and 2,000 and then buff it out with polish.
Old 12-13-2005, 11:56 AM
parbreak's Avatar
There is only ONE way and that's break out the fine grit paper and lots of water.
Old 12-13-2005, 11:59 AM
ZaneO's Avatar
Yup.
Old 12-13-2005, 12:01 PM
Mark IXZD 150's Avatar
I usually start by slicing through the skin, quartering the sphere, just deep enough not to cut into the pulp sections. Then, grasping the fruit firmly yet not too hard that I would crush it, begin to peel each quartered skin section off. It's important to remove as much of that whitish stuff too because it's kinda tough and ruins the taste...
...Runnin' and duckin'!
Old 12-13-2005, 12:12 PM
parbreak's Avatar
So what about banana peel?????
Old 12-13-2005, 12:42 PM
TNTramair's Avatar
clay bar works pretty good...depending on how bad the orange peel is.
Old 12-13-2005, 12:45 PM
skippytheloon's Avatar
Just keep the orange-peel on there, its good for ya.
Old 12-13-2005, 01:28 PM
CashMoney's Avatar
I have to know I tried going all day but how did you get orange peel on your paint?
Old 12-13-2005, 04:40 PM
Use Mark's method to seperate the peel from the orange, then apply liberally to car exterior...why would you want orange peel ON your car?
Old 12-13-2005, 04:44 PM
02blackws679ta's Avatar
how do you figure clay bar would have any effect what so ever?
clay bar? that wont fix a bumpy "orange peel" paint job. funny
Old 12-13-2005, 07:09 PM
SSilverSSurfer's Avatar
werd...
Old 12-13-2005, 08:17 PM
trever phillips's Avatar
start off w a d-a till its getting flush then color sand w 2000 and buff w wool pad w heavy compound then light compound then foam pad w polish. thats the fastest way!
Old 12-13-2005, 08:19 PM
JerseyLS1TA's Avatar
What exactly is orange peel?
Old 12-13-2005, 08:20 PM
the paints finish or i should say the clears
Old 12-13-2005, 09:23 PM
stryker14's Avatar
Haha. That would definately be the fastest way but seeing as how he isnt quite sure how to remove the texture in the first place I dont know if having him go at it with a DA would be the best choice lol. I can just see him coming back with pictures of the car he sanded with no clear left on it.
Old 12-13-2005, 09:45 PM
ya good point! speed is'nt always the best use 800 then follow up w 1500 then block sand w 2000 hay just in case
Old 12-13-2005, 10:50 PM
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
i agree then some microfinish and polish
Old 12-14-2005, 12:38 AM
freeeakz28's Avatar
a da? 800 grit? i dont think so. im going with stryker on this one.
Quick Reply: Best way to remove orange peel
