Ti retainers waste of money?
Old 12-13-2005, 04:36 AM
LastBlack02SS's Avatar
Default Ti retainers waste of money?
Look at the mods in the sig. Getting chromoly pushrods. Is getting ti retainers for the comp 918's a waste of money? What is the weight difference? How will it affect things?
Old 12-13-2005, 05:26 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
The lighter your valvetrain the better. If you can afford to get TI....do it.
Old 12-13-2005, 05:35 AM
vettenuts's Avatar
With a Z06 cam I don't think it is worth it. I would however suggest the Comp steel retainers because they fit the spring better than the stock ones.
Old 12-13-2005, 05:38 AM
Predator's Avatar
They probably weigh about 50% less than the stockers. I was amazed when I held one of each in each hand. I'm glad I put 'em in.
Old 12-13-2005, 07:41 AM
TAQuickness's Avatar
take a look in the advanced tech section for a thread along the line of "weight over the valve"
Yes it makes a difference, and yes it's worth it
Old 12-13-2005, 10:27 AM
dug
dug's Avatar
Katech sez ti retainers will give you a 200 rpms more till valvefloat.
Stock retainers are small so theyre already light. Ti retainers are needed more for dual springs cuz theyre so much bigger.
Old 12-13-2005, 10:36 AM
c5dream's Avatar
all you ever wanted to know about Titanium.
http://en.wikipedia.org/wiki/Titanium
Old 12-13-2005, 11:34 AM
vettenuts's Avatar
While I agree the titanium would be better, the question remains does he really need them? I don't think he does because he has Comp 918's on a Z06 cam, and if the Z06 springs can keep up with that cam the Comps should not have a problem either. The Comp retainer is a better fit than stock, so I would just go with the steel retainers from Comp for best fit.
Old 12-13-2005, 11:48 AM
MrDude_1's Avatar
does he need them for a z06 cam? no.
would they benefit him? eh, not really anything measurable.
does someone with a aftermarket, aggressive ramped cam need them with 918s? no.
would that person benefit? yes.
getting another 200rpm or so before valvefloat is great... if your engine likes spinning that fast... with a tiny cam that cant use the RPM, and a not-as-agressive ramp on the lobe, the cost vs benifit is obviously in the "why bother?" catagory.
Old 12-13-2005, 12:26 PM
nuzee's Avatar
Notice the Ti vs. steel weight breakdown by valvetrain component towards the bottom of the following article.
http://www.krcperformance.com/newcontent/beehive.html
It gives you a total-picture perspective of the valve train mass and the weight benefits of going Ti on the 918 retainers. I agree with dug.
Old 12-13-2005, 02:16 PM
DONAIMIAN's Avatar
It depends on how high your spinning the motor. If you were shifting by 6200, I couldnt justify them because of the cost.
Old 12-14-2005, 12:10 AM
Loving the input. It really is just whether or not upping to TI retainers as opposed to the comps on my setup is going to make a noticeable difference.
