***need Wiring Diagram For Starter***
Old 12-13-2005, 06:30 PM
777's Avatar
Default ***need Wiring Diagram For Starter***
Like the title says. I need the wiring diagram for the starter on a 98 firebird formula. I'm trying to figure out why my car has nothing when trying to crank. Like the clutch is not depressed. (even though it is). Maybe bad starter, maybe starter wired wrong, maybe clutch safety switch broken. I also broke the wires that go to the sensor that goes into the oil pan. I assume this is the sensor to tell when you have low oil level. Anyhow, I need help asap!! Possibly even a blown fuse maybe. I checked almost all of them. Which fuses would have anything to do with what I'm talking about?
Old 12-13-2005, 10:11 PM
volcom666dj's Avatar
i would take your starter off and bring it to a shop to test it or you can test it yourself
Old 12-14-2005, 08:17 AM
777's Avatar
Ok, I'll do that. Anyone have a wiring diagram though?
