Dart Heads- Anyone running them yet
Old 12-13-2005, 07:22 PM
john59's Avatar
Default Dart Heads- Anyone running them yet
Hi Guys,
I'm in the market for a set of heads after the holidays and wanted to know if anyone has run the new Dart castings in the 1/4. And what kind of power there putting to the wheel as cast and ported with a given combo.Is it to early for this info? I like AFR's and ETP heads but if i can come close with the Darts and save some money, I'll put it to use somewhere else in the car.
Thanks
John
Old 12-14-2005, 07:48 AM
john59's Avatar
ttttt
Old 12-14-2005, 07:53 AM
rjw
rjw's Avatar
Location: Tinker till it blows, then back it off a notch, maybe!!
Too early to tell.
I have a set of 225's going on an engine rebuild, but it will be hard to tell what the heads alone add or retract from this setup. (Too many changes)
Give it some time
Old 12-14-2005, 08:17 AM
XIII's Avatar
Do a search for a member on here 427
He works for Wheel-to-Wheel and he posted his findings from thier engine dyno vs. ported 5.3 castings recently. Those are the only results I have seen. I havent seen anyone post track times yet.
Old 12-15-2005, 09:54 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
We have them in stock & I posted the flow sheets in a dart specific post in the internal section They seem pretty nice & with a little cnc work they should really flow great!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 12-15-2005, 11:26 AM
john59's Avatar
Thanks Guys, I'm going to put heads on in mid January, so hopefully by then there will be more info. so I can make a decision. I'm looking for the best bang for the buck and it would be really sweet if these heads work well. I know AFR's are the cream but if i can make somewhat comparable power with the Darts I'm in..
John
