mid length or shorties ?
ok Im looking at a set of mid length and shorties and see little or no difference. my first question is what is the difference ? next question is can I go full length or LTs without sacraficing clearance , as I am sporting sportlines and Im sitting pretty low. and finally which would best compliment a turbo application ?
~Guy
~Guy
I don't think you could do longtubes with a 2" drop and have any decent amount of ground clearace. Go witht the mid-length tubes, shorties won't net much power, your stock manifolds on your 2001 SS are actually better flowing than you think. Shorties wouldn't be a good $-power investment.
damn the bad luck sucks you cant have it all heh? so whats the dif between mids and shortys since I cant see much of a difference at all visually ? I have been leading towards the mids anyhow because the car is lowered and I had shortys on my old car a 2000 SS. and lost a lot of low end and gained a little high end. will I still lose low end with the mids ?
~Guy
~Guy
one of the locals in vegas has an STS, and he switched his SLP LTs to the stock manifolds; said they were better for turbos. he's a turbo guru and pushing about 625 rwhp so maybe you don't need exhaust manifolds if you plan on re-installing that STS.
