twin turbo 427
Old 12-14-2005, 06:25 PM
427ImpalaSS's Avatar
Default twin turbo 427
which would be a better block to have resleeved an Ls1 or and Ls2 for a twin turbo 427 setup. would ls6 head be sufficient enough to support a motor like that. not trying to go too high in hp just around 7-800. what about ls7 heads I think I read that they would bolt to a ls2 block, would I need ls7 intake also for that. thanks
Old 12-14-2005, 06:45 PM
TchargedLS1TA's Avatar
Any head with a good port job will give you good HP.. Why not go with a C5-R block?
Old 12-14-2005, 06:46 PM
bluecamaroz28's Avatar
I would say better go with smaller cubes. Back pressure will be too much with turbocharged 427 compared to stock cubes LS1.
Old 12-14-2005, 06:47 PM
GTObsessor's Avatar
If it were me, I'd go for a re-sleeved 427 LS1 with a FAST 90mm intake and some nice big ET heads.... that's jsut me... not sure about the LS7 heads myself either... any way you go, you're gonna have a monster.
Old 12-14-2005, 06:48 PM
OldBlue's Avatar
C5-R...............
Old 12-14-2005, 08:08 PM
maddboost's Avatar
Resleeved LS2. FLP did one recently with their own twin turbo setup on a Z06 and its made 750 rwhp so far on 93 octane. It was a resleeved LS2 to a 408. The sleeves in it are actually thicker than a C5R block.
Old 12-14-2005, 08:10 PM
BLk01SS's Avatar
don't go C5R, not since the World block is out and is a better block and is a couple grand cheaper. If your only looking for a resonable hp level, I'd get a resleeved LS1. Check out MTI for a sleeved block. for heads, get some 6.0 heads and have some porting done on them. If you get LS7 heads, your going to need a LS7 intake, those heads are different than the other LSX stuff.
You can however, save a good little chunk by going with a 402 or 408 iron block. Both are great motors, and perform just as good, if not better. The 427 tax is high.
Good luck
Old 12-14-2005, 08:40 PM
mahhddgtp's Avatar
What's the world block?
Old 12-14-2005, 08:47 PM
mdhmi's Avatar
I would stay away from the resleeved blocks. Either CR5 or stay with stock cubes. You can easily make 700 rwhp on a forged 346/7.
Mark
BLk01SS's Avatar
I think its called the Warhawk. Check Hardcores site
Old 12-14-2005, 08:49 PM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
another vote for World block.....6 bolts/head+mega boost
or race preps 500 ci motor that just came out
Old 12-14-2005, 09:27 PM
LS1TECH Sponsor
JZ 97 SS 1500's Avatar
Depending on ther turbo setup makes a big difference on what cubes to run.
Jose
Old 12-14-2005, 09:35 PM
LSONE's Avatar
IIRC the LS1 block is stronger than both the ls6 and ls2, and is therefore preferred for resleeving. IMO you should go with the WP block, it's a bad *** looking setup.
Old 12-15-2005, 12:26 PM
LTLHOMER's Avatar
35x inch iron block if you're looking for cheap and reliable. Stock crank, some eagle rods and a good piston and you're easily making what you want to make.
My junk uses stock ls1 block, heads, crank, with a set of used eagle rods and a good piston and it makes pretty good steam and it is almost entirely used parts. Just spend the money on good machine work and assembly.
No sense going off the wall when you're only looking for 7-800 and the extra weight from the block is meaningless.
Old 12-15-2005, 12:32 PM
NoMoreLS1's Avatar
Thumbs up
It'll makes more power than that. It's just impossible to get an accurate reading when the car spins the tires on the dyno even with 2 people (500 plus pounds) sitting in the trunk.
Old 12-15-2005, 12:34 PM
NoMoreLS1's Avatar
Smile
Oh yeah... that's not too high.
Old 12-15-2005, 12:35 PM
NoMoreLS1's Avatar
Smile
Yeah... only 700 to 800 rwhp.
Old 12-15-2005, 12:42 PM
98turbls1's Avatar
Well considering that stock cubed LS1s make that much with a T76 that really isn't that much...With a 427ci he could easily be over the 1000rwhp mark with what he's trying to do...So if he's "only" trying to make 7-800rwhp I would stick with a 346...There's a lot of reasons for this..One is look at all of the rotating mass that you have to spin...Plus you have to clearance the block for the throws which therefore weakens the block...It would be cheaper and more reliable to run a 346 if his goals were to make 7-800rwhp max...that would equate to a very streetable 500-600rwhp on the street which in my book is no slouch...
Old 12-15-2005, 01:08 PM
oh I forgot to post this isn't anf f-bdy car its an impala. 7-800 is just a figure. I would mind it make more, but I guess what I'm trying to say is I'm not looking to build a race car just a 427 tt impala. So I figured a nice streetable figure would be 7-800.
Old 12-15-2005, 03:37 PM
BLk01SS's Avatar
buy a LS7 crate and stick a turbo on it, or a procharger. That would make all the power you would want and still be a good reliable setup.
Quick Reply: twin turbo 427
