Folks with FI and Vacuum modulated trannies inside, please
Anyone running 10 PSI or more? If so, what type of vacuum line are you using from the tranny to your vacuum source for the tranny modulator? the clear hose with the spring inside? I'm at 11 PSI and am having the vac mod installed today and am concerned that even with the bypass valve (that TransGo supplies) installed that the extra pressure may burst/split the clear plastic vacuum line. The install instructions mention that at 10 PSI or above that "pressure hose" should be used. Anyone with hands-on experience?
Don't use that cheap clear hose. You can just purchase a pre-bent hard line from FLP.
You can e-mail Chuck at Transtech@finishlinetrans.com.
Mitch
LS1TECH Sponsor
hose
Just get some silicone hose..............
Mitch
Mitch
Originally Posted by engineermike
I'm using regular black rubber vacuum hose with not problems up to 20 psi so far.
Originally Posted by DanaliHD
why is this the first I've ever heard of this? I'm running 15lbs of boost with my whipple and never touched the transmission other than to install a stall. Hook a brotha up!!!!
Originally Posted by FLT
Scott,
I sent you information and some pictures to help you make a hard line. I like this way better than using rubber hose.
Chuck/FLT
Chuck/FLT
Got the emails and pics...THANKS! After much deliberation, the tranny tech and I have settled on braided SS brake line, as he has some extra in the shop and says he also can get the right fittings for the ends. Should work as good(well) as it looks. I will post up on my final outcome with the vac mod and the Edge 3000 stall.
