General Maintenance & Repairs - Need a torque spec...
View Full Version : Need a torque spec...
Lithium
12-15-2005, 07:45 PM
I had to loosen those two bolts that go through the tranny into the oil pan to drop the pan a bit. Forget the size of them...13mm or 15mm?
Anyway I have searched and found nothing on what it should be torqued to. I remember reading a while ago though thats its around 35 lb ft?
Thanks for the help.
67Ranger
12-15-2005, 08:19 PM
if they are the long ones that go into the rear cover they are 12nm (about 8 ft-lb i think)... if they are the pan bolts, then its 18. For future refrence, http://www.ls2.com/boggs/torques/enginetorques.htm#Application
Lithium
12-15-2005, 08:24 PM
No, its not the little ones or the oil pan bolts.
They go through the tranny into the oil pan...
Lithium
12-15-2005, 08:45 PM
Is this right?
Tranny to Bellhousing bolts - 26 ft lbs?
Lithium
12-15-2005, 10:35 PM
bump...anyone?
TheBlurLS1
12-15-2005, 10:42 PM
37 ft/lbs DUH!!! :P
This is what i though was right, but i checked ls1howto.com anyway ;) He has a whole page with specs on it.
http://ls1howto.com/index.php?category=1
Hit controll F and type housing if you dont believe me :D
Lithium
12-15-2005, 11:01 PM
Your a good man!
Thank you.
Thats the first place that I looked actually. I was not sure if that was what I was looking for or not though...cause I dont know what the hell its called :jest:
