Nitrous Oxide - MAF for dry NOS kit
View Full Version : MAF for dry NOS kit
1999TransamWs6
12-15-2005, 08:42 PM
What MAF is good for the NOS 5177 kit? Im spraying as much as it will flow and I run the F.A.S.T 90/90 set-up with stock MAF so obviously I need a higher flowing one. Which should I go with? Thanks.
383LQ4SS
12-15-2005, 09:02 PM
personally I would stick with the stock piece. Do you know if the MAF is being maxed out? What size shot do you estimate your hitting the MAF with. Also what injectors are you using.
ceo44
12-15-2005, 09:29 PM
I agree with 383. I have 3 stage, 2 dry and 1 wet and you will be hard pressed to max out the stock MAF on a dry shot.
1999TransamWs6
12-15-2005, 09:57 PM
Im running (Estimated 150rwhp dry shot) Dual .052 jets with 42lb injectors. Not shure if the stock piece is maxed out how would I know? I have HPtuners if I can tell through that.
Robert56
12-15-2005, 11:00 PM
Actually, the Z06 Maf and tables has a higher flow than than the ls1 mafs, that'ed be my choice if stocker was being maxed.
Robert
383LQ4SS
12-15-2005, 11:27 PM
With the 42 lb injecters tuned in you should be able to hit around 650+ rwhp total safely.
Some have gone much higher with tuning tweaks and thinks like voltage blasters for the Walbro intank fuel pump. As much as 800+ rwhp.
1999TransamWs6
12-16-2005, 10:49 AM
thanks for the information it makes me feel better that im spraying a dry kit however, im concerned with getting a higher flowing MAf (Air)(85mm) or should I not worry about this? Will it be much of a difference?
