Codes and O2's
Old 12-15-2005, 08:45 PM
Darksol's Avatar
Default Codes and O2's
I took my car to get it scanned today and it threw out a PO134. So my question is which o2 is it? And isn't there a special tool for removing one or am I on crack? I know the sensors are on the exhuast but which is which? Thanks in advance guys.
Old 12-15-2005, 09:42 PM
LS1Tech Administrator
RPM WS6's Avatar
Received 1,486 Likes on 1,069 Posts
My book says P0134 = O2 sensor circuit no activity detected, bank 1 sensor 1. That would be the driver's side front (pre cat) O2 sensor. They just come off with a wrench, can't remember the size off hand though. I know I've used a crescent wrench before.
Old 12-16-2005, 08:12 AM
black01_WS6's Avatar
you are right, if you ever have another question about codes the stickeys have all the info you need. it covers all the codes. or put your code in the search and you will find vast amounts of info.
Old 12-16-2005, 10:55 AM
Darksol's Avatar
when i put the code in the search box it came up with other codes as well.
thats how i knew it was the o2 sensors. i try to search before i post. thanks though.
