Gears & Axles - Cover Change with Gears
Silver-Dollar
12-16-2005, 07:58 AM
Did you change the differential cover to a performance aluminum cover when you changed gears? I am going from 3.42s to 4.11s. With the 4.11s containing less material than the 3.42s, I figured it would be a good idea to do so. What are your thoughts?
Predator
12-16-2005, 08:17 AM
I put on a TA cover with 3.42s and I haven't had any problems with my 10-bolt. I'm going with 4.10s, but I'm switching to a 12-bolt.
With that being said, I think the cover can only help, especially if you install the supplied studs. And if you're staying with the 10-bolt, you're gonna need all the help you can get.
Silver-Dollar
12-16-2005, 08:33 AM
That is what I figured, a little cheap insurance. I had one in my hands, but the company shipped a 7.5" and not an 8.5". I began to question if I really needed it.
From what I have seen, there are good variety of them out there. Any preferrences?
They are all relatively about the same price, but I have seen covers from:
Strange, Moser, LPW Racing, Summit, Jegs, and TA Performance.
Plus, is there any problems with leaking around the bearing preload screws?
Predator
12-16-2005, 09:41 AM
I have a TA cover and its been fine, don't know about the others. I haven't had any leaking at all, and no leaking from the preload bolts. I used a gasket without RTV. I hear they leak if you use a gasket and RTV. If you use RTV you don't need the gasket, and vice-versa. Also, I followed the torque specs exactly.
Silver-Dollar
12-16-2005, 11:51 AM
I was going to use RTV without the gasket. Thanks for the input.
Predator
12-16-2005, 12:27 PM
Welcome. I noticed you have a truck, although I'm not sure what a RCSB is, but you should be all right with a 10-bolt. If this is a regular type of truck, I don't imagine you'll be doing 6k launches, plus traction is horrible with every truck I've driven.
Silver-Dollar
12-16-2005, 01:12 PM
Regular Cab Short Bed. No 6k launches planned. And yes, I am going to be traction impaired for the most part.
Predator
12-16-2005, 02:37 PM
You should be all set then, and the cover and stud kit can only help.
Good luck!
dailydriver
12-16-2005, 02:59 PM
I have a Mac cover on my 10 bolt with 4.10s. NO problems, leaks or noise. I'm using the Lakewood BFL dino fluid 80W-90. RTV, no gasket. The TA cover is just as good.
