Will my 2 1/2" Exhuast Handel FI POWER?
My exhaust setup right now is:
Hooker SuperComp LT into a Custom 2 1/2" Y-Pipe into a 3" I-Pipe with a Electric Cutout then into 2 - 2 1/2" pipes through 2 Dynomax 23 1/2 Bullet Race Mufflers.
How much HP do you think my current setup can handle...
I figure I will be pretty close to 500HP when everything is completed with my new Procharger setup will this be able to handel it?
I don't see where the exhaust won't be able to support the horsepower, especially since I didn't see a cat in there. I see no reason why you won't see 500 rwhp on a DynoJet dyno. I don't suggest using an electric cut-out with forced induction, unless you make sure the tune is right on with the cut-out open. It is very critical to have a good tune when using forced induction, and the open cut-out could very well throw the tune off.
You are going to want to use the 42 lb fuel injectors, don't go any smaller than 42's. Bob
