Tap into MAP wire?
Old 12-16-2005, 08:23 PM
Pavetim's Avatar
Default Tap into MAP wire?
I have an 02 WS6 and was wondering if you know where I could tap into the output wire for the MAP sensor so I can hook it up to my Innovate wideband? Thanks.
Old 12-17-2005, 07:08 PM
WS6FirebirdTA00's Avatar
might have to pull it off the pcm, not sure the pin though
Old 12-17-2005, 08:08 PM
Pavetim's Avatar
Thats where I hope to pull it off of since can't get at the sensor. But I need to know what pin. But thanks anyways.
Old 12-17-2005, 08:23 PM
ill see if i can find anything in this book i have, if i do ill post back up
Old 12-17-2005, 08:44 PM
Pavetim's Avatar
Think i got it, found couple diagrams. But if you find anything let me know just as a double check. Thanks.
Old 12-17-2005, 08:51 PM
Pavetim's Avatar
Ok pretty sure I got it but there are 3 wires the MAP sensor signal, low reference, and 5V reference. You know what one i'd use? I'm guessing the map sensor signal but not sure
Old 12-17-2005, 09:12 PM
i know on my shift light they mentioned it had to be modified for a 5v signal , im not good with electrical but i would think it woud be the 5v ref or the signal (of course the signal would make sense if that is the output for the map value)
Old 12-17-2005, 10:06 PM
Moderator
jimmyblue's Avatar
Red 32 Lt Grn MAP Sensor Signal
Believe MAP is straight line, 0.25V at 20kPa
to 4.85V at 102kPa. For regular Delphi 1-bar
ones anyway.
Old 12-18-2005, 05:24 AM
Pavetim's Avatar
Sweet thanks alot guys this just might save me $150 instead of getting the hptuners eio upgrade.
Old 12-18-2005, 10:01 AM
97c5's Avatar
Jimmy,
Do you know the pin out for the 97-98 pcm. Thanks.
Old 12-18-2005, 05:21 PM
97c5's Avatar
ttt...
