Holy Pressure ratio bat man... BW turbo maps
Ok here is a popular garret compressor wheel.. Look at it then look at the Borg/Schwitzer maps. http://not2fast.com/turbo/maps/gt35rcompress.gif
Now check out these Borg Warner wheels..
S200
Jezbus fliping cripes... Not so much the lbs/min but the P/R Anybody want to run a 4.0 pressure ratio?
S300 Still pretty high P/R a touch more lbs/min
S400 high P/R and Huge lbs/min
S200
If you want to compare apples to apples, here ya go.
This is the GT42 compressor map. At first glance the B/W compressor maps look like they have wider islands of efficiency, for the most part this is just the way they scaled their map (along the bottom) in comparison to the Garrett maps. The GT4202 compressor wheel will go HIGHER in P/R (not that anyone here will run over 40 lbs. of boost) and potentially flow MORE at 4.0 PR (91lbs/min versus 87 lbs/min). This wheel should be close to the S400 in size.
LS1TECH Sponsor
The new BW units are awesome indeed, but getting your hands on them is the hard part. The S400 is a replacement for the GT42. Only problem with the S400 is the A/R ratio. Its only available in a 1.32A/R. As for power, the S400 on our compound diesels will outpower the GT42 by a wide margin. Turbine wheel is the big difference between the two. The S-trim wheel is smaller and chokes off much earlier.
JZ
JZ
Nothing an aftermarket turbine housing cant cure... Kind of like the holsets I have seen on 2.0's.
ATS is running them forcompounds on the CTDs..
http://www.atsdiesel.com/ATSWebsite/...rboSystems.asp
I wonder which wheel is in the aurora 5000... That one looks like a holset compressor cover.
It can run comfortably as a single at 60psi..
Their aurora 2000 is a s200?
JZ
JZ
Originally Posted by V8_DSM_V8again
Well... I was originally looking at the GT35 vs the S200 for twins..
How about a 4.4 pressure ratio with room to spare?
I'd rather have a turbo efficient in the area I use than the area I don't.
