Nitrous Oxide - First Nitros kit!.......
hunterdawgs
12-17-2005, 03:29 PM
I'm going with the ZEX system because I like the Active Fuel Control.Anybody with ZEX can give me any info would be appreciated.I'm not planning on getting bigger than a 150 shot and I've got TEA stage 2 heads and a Comp cam( around .220-.222& .560 lift range with about 114 LSA).Staying with the stock stall for now.
Hooper
12-17-2005, 03:45 PM
You really should consider getting a good aftermarket stall to take advantage of your other mods. Maybe a Vig3200 or higher. Just a thought.;)
Matt@HSW
12-17-2005, 04:33 PM
I would suggest upgrading your fuel pump, if you haven't done so already.
Matt
hunterdawgs
12-17-2005, 05:05 PM
MattHaven't upgraded yet because I really didn't know I needed to .Didn't think I had enough to warrant it.
hunterdawgs
12-17-2005, 05:07 PM
You really should consider getting a good aftermarket stall to take advantage of your other mods. Maybe a Vig3200 or higher. Just a thought.;)Just don't know about a stall yet,like to drive mine on the street too much.
Caribe
12-17-2005, 07:07 PM
In that case you will love it even more when you get a torque converter. I have a TCI 3500. It revs up a little higher when you give it partial throttle, but when you get on it, it goes. I also have a Zex kit that I use once in a while. Very easy to install. All Hp ratings are rated at the crank. So the 125hp pills are about 100 to the wheels. I would definetly go for the TC and a shift kit first.
Matt@HSW
12-17-2005, 09:54 PM
I would highly suggest doing one since you are already a heads/cam car and plan on spraying up to a 150 shot.
Matt
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
