A little Hint for Guys to play around with in EFILive
Old 12-17-2005, 11:06 PM
wait4me's Avatar
Default A little Hint for Guys to play around with in EFILive
Table B4206
Old 12-18-2005, 12:03 AM
Bink's Avatar
Originally Posted by wait4me
Table B4206
That's slick!
Thanks Jes!
Old 12-20-2005, 10:23 AM
LS1TECH Sponsor
foff667's Avatar
Old 12-20-2005, 10:28 AM
MrDude_1's Avatar
Old 12-20-2005, 10:32 AM
MrDude_1's Avatar
sooo is this commanded AFR availible to us HPtuners guys too?
Old 12-20-2005, 10:34 AM
HumpinSS's Avatar
When disabled, the PCM will always use
- {B3605} Commanded Fuel When in Open Loop or
- {B3647} (not available in this operating system) as the fuel mixture table without any O2 feedback as long as table
- {B4205} Closed Loop Temp Enable is also set to it's maximum value.
If this parameter is enabled then O2 feedback (STFT) will be used with the Open Loop table.
If you wish to run total open loop disable this parameter and set
- {B4205} Closed Loop Temp Enable to it's maximum value.
Only the following values may be entered into this table:
- Disable
- Enable
Prolly not i didnt see it in 1.7
Old 12-20-2005, 10:48 AM
LS1TECH Sponsor
foff667's Avatar
its not really a commanded afr more or less just saying not to learn anything lol
Old 12-20-2005, 10:49 AM
SmaknaSS's Avatar
Is that parameter # in a costom O.S.? I didnt see that # when I did a search in my EFIlive software.
Old 12-20-2005, 10:52 AM
LS1TECH Sponsor
foff667's Avatar
i found it in my demo version but just a regular file
Old 12-20-2005, 11:57 AM
HumpinSS's Avatar
Actually that table enables stft learning in open loop instead of just closed loop only. In the stock file it is diabled meaning it doesnt learn in open loop. I you enable it and command 15.5 in the OLFA table the pcm with try and trim to meet the AFR....
Its in the stock os's and v1 and v2 it is removed in v3 for obvious reasons
Old 12-20-2005, 12:14 PM
kbracing96's Avatar
So that why I couldn't find it, I'm runing COS 3...
Old 12-20-2005, 01:31 PM
Moderator
JNorris's Avatar
How accurate do you think the AFR would be considering you are using the narrow band O2 sensors?
John
Old 12-20-2005, 01:36 PM
HumpinSS's Avatar
Not sure I personally would verify with a WB if they are capable of doing so. I figure if the aussies run lean cruise and the narrow bands operate fine for that it should be able to trim for 15.5:1 although i wouldnt go any leaner than that
Old 12-20-2005, 01:41 PM
MrDude_1's Avatar
John
depends.......
... how accurate is your tune?
Old 12-20-2005, 03:13 PM
Brains's Avatar
Its a calculated AFR, similar to how the aussie cars do lean cruise. If your VE table is accurate, its actually pretty darned close. I did the EFILive "AutoTune" on my car, and then played around with it, pretty darned slick.
Old 12-20-2005, 03:21 PM
wait4me's Avatar
Just another thought for you guys to think of, A wideband is accurate is it not? A wideband is configurable on its voltages right? You can set the o2 sensor to put out a 0 to 1 volt right? Getting my autofuel hint yet???
Old 12-20-2005, 03:29 PM
Kleeborp the Moderator™
MeentSS02's Avatar
I'm not quite tracking...could you spell it out a little more clearly?
Definitely a cool idea, and a wideband set to 0-1v would be the only way I'd do it after watching my narrow bands take a **** on me this weekend. I mean, don't get me wrong...I enjoyed watching my fuel trims swing full positive as my O2s flatlined at 0mV
Old 12-21-2005, 02:52 PM
Zeus's Avatar
no
Old 12-21-2005, 03:00 PM
MrDude_1's Avatar
whats the resolution of the 5v D/A converter on most widebands.. like the LC1 for example?? 8bit? 16?
Old 12-21-2005, 06:00 PM
Tomcat's Avatar
No , what it will do is if its in open loop and it sees a table entry of 14.63 then it will go into a quasi closed loop in this area
Quick Reply: A little Hint for Guys to play around with in EFILive
