Next Mod: Big or Basic?
Should I keep doing performance mods such as LCA's, clutch, nitrous, or throttle body or should I go back to basics and do plugs, wires, all new fluids, etc.?
I just hit 24K and I havent done anything besides oil changes since it came from the factory. If I do all the little things, what oils (transmission, differential, etc.) should I use and what are good spark plugs to use? Also, is there a point in changing the spark plug wires?
That's what she said...
As for differential, do a search. There was a posi-unit change over during the production run, and some require different fluids. Some require GM limited slip additive and some dont. Some can accept synthetic fluid and some cant.
Running the k&n part number 2006 oil filter is also a good idea. It's a longer version of the one for f-bodies and flows better and offers a little more oil pressure, plus they filter great and have a 1" nut on the bottom for easily removal
With your low miles, the car is just getting broken in though! Plus/wires are probably fine for now.
BTW - Do you have the factory shifter? Is it the hurst? If its stock, get a new one (pro 5.0 here and i love it), if its the hurst, get a short stick for it and you will like it more. The factory STICK is usually what causes crappy shifting. Its got a big rubber isolator connecting the stick to the shifter and has too much slack. As one of my friends said...
"put the pro 5.0 in, and it went from UPS truck to F1"
