Cadillac CTS-V - ls7 bare block
platinum
12-18-2005, 06:55 PM
does anyone know the part number for the bare ls7 block. i want one to put in the v
platinum
12-18-2005, 07:16 PM
anybody? come on parker, you must know lol
Parker TX
12-19-2005, 08:24 AM
Why would you just want a bare block, you still need to use the ls7 heads on it. Well anyways I couldn't find a part # for just the block, but here is the # for the entire crate motor.
obZidian
12-19-2005, 12:47 PM
LS7 crate motor = 17802397
This is the part numbetr on the whole motor. But Parker brought up a good point. You will have alot of work to do to make it right. ALso, this is a fairly new block and any issues or bugs havent fully surfaced...if any.
If you want to go big cubes, i would recommend either an iron 408ci or an aluminum 402ci setup. Also, there are 370ci iron, 382ci aluminum, 385ci iron or a small 500ci aluminum/iron...not sure on this on though.
With these, you will have a better time finding reliable setups and will have the to drop less cash and require less research to make the ls7 work. If what your looking for is to have a LS7-CTS-V, than get the crate motor longblock....your best bet because this is a finished product and its a delicate motor that should be carefully put assembled.....'
good luck!!
Mat347
12-20-2005, 02:53 PM
You should check out the new aluminum truck block GM is offering. Everybody seems to have plans with big cubes using them. The crate engine even comes with forged crank/rods I think.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
