how much psi can I run on stock bottom
how much psi can I run on stock bottomI have a 1999 z28 6speed I have the following but no installed
sts turbo with upgraded 67mm turbo and a ls6 intake, I want a set of headers no cats and a set of heads like the 6.0 heads.what boost can I run with this set up? what else should I get I want to leave the bottom stock for now and I would like 525 at wheels I have the elky kit too
been doing 15psi for a while on the 76, did 16 several times on the old t67. Gonna push a friends stocker to 18psi or so with some 6.0 heads and a t76. Only bottom end mod is rod bolts.
Boost is a horrible way to measure things, it's just restriction. Don't detonate or go lean and the amount of boost is irrealevant.
The general consensus is that 8 psi with a good tune is reliable. The key being a good tune.
