Steeda oil seperator
Anyone run this? Yeah, it's for a mustang but will work on our cars. Looks like a good alternative to the catchcan everyone here runs.
http://spmotorsports.com/ATCmisc_flu...ators_oil.html
Originally Posted by snketr
That's the exact same thing you can buy for $20 at sears. It's for an air compressor basically. Campbell Hausfield makes them. I got mine at AutoZone.
http://www.sears.com/sr/javasr/produ...ol+Accessories
Same setup here, got everything at home depot for 20 bucks, made my own bracket where the egr used to be, I would like to here more from ferocity about how his setup clogged up?????
i have had mine on my supercharged matrix for several thousand miles and no issues i just take it off and clean it every once in a while i just put one on my camaro heres some photos, i just put it on like i said i am going to clean it all up soon, basically there is the catch can collector on the pcv to intake manifold, and then a filter which catchs some but mainly just cleans i replace with oil changes, is on the valve cover to TB:
What is that clear fuel filter? hooked up to? I went to Lowes yesterday and bought a smaller air compressor filter and hooked it up inline after my pcv valve. It's alot smaller than the other one I was going to try to use. No oil in it yet. Although I did order the pcv valve for oil consumption problems (I've got the part # here somewhere) from the Chevy dealership for $10 on Thursday, it should be here Wed. or so. Maybe that'll help as well.
its hooked up to the breather valve off your valve cover (passenger side) which breathes to the TB and often dirtys the TB so i put a filter there too heres what my TB used to look like compared to know:
