PCM Diagnostics & Tuning - 2006- 5.3 gms disables cyls
zrater
12-20-2005, 01:23 PM
:confused: 2006 monte carlo and 06 impala 5.3 ls4, shuts down cyl when up
to speed, what does hptuners have in there pocket for
tuning reduction of cyl on theses models for all 8 cyl to stay on
boarrd for the drag seen............
2002_Z28_Six_Speed
12-21-2005, 07:11 PM
I thought if you were at WOT it was in 8 cylinder mode despite the speed?
SRPerformance
12-21-2005, 11:34 PM
AT WOT it would be 8 cylinder but I am guessing you want to know does HP Tune have software to tune when it cuts in? BTW, variable cam timiing should be controlled by the VCM as well.
I would like a answer as well as the L76 which has DOD and variable cam timing will become available in Commodore after 1st January 2006.
ringram
12-22-2005, 04:05 AM
I dare say it will eventually be tunable, once the PCM is cracked.
Should be able to run it like lean cruise and lower the trigger point where 8 cyl comes on. Like PE mode.
rkinney
12-24-2005, 10:48 PM
There is a very fine line when DOD actually kicks in. Very steady throttle, I think somewhere over 40 mph, and other conditions. Just controlled through solenoids which direct pressurized oil to the the lifters which retracts the lock pins collapsing the lifter and keeps from pushing up the pushrod keeping the valve closed. Should be able to disable the solenoids in due time I would assume.
WS6 GreeN
12-25-2005, 12:49 AM
Variable cam timing? So does that mean they have VTEC? :)
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
