Anyone using an AAM cover?
I just got back from the junkyard to look at a '97 SS. I ended up helping the owner out with a few things so I picked up this AAM cover off the SS for free. (the car looks like a train hit it so I couldn't find much else...except for the six speed which I still might get, for $1700 complete).
This cover is just a thick aluminum cover. I did a google search to find that SLP now sells these for $99.
Anyone use one of these? Guess I'll put it on because I have it. It's not the type with the preload bolts though.
Here is a pic of one.
Originally Posted by Dear John
It does nothing for strength as the TA girdle does. It's more for looks and cooling I believe.
It you got it for free, at least it looks nice.
Get a TA later.
Get a TA later.
Actually the car it came off of was hit so hard the right axle tube was broken off, the cover wasn't touched. I don't know what that has to do with anything.
It was free, can't go wrong.
Yes I found that somehow. The instructions that has cutout templates, i printed them out, you put the template up to where the side bearings go and grind a small channel into the case, this allows oil to drain back.
Kind of sucks to have to pull the diff to modify the housing to put a cover on just for looks.
I doubt I need a cooler rear, maybe it'll be enough to keep the oil thick and leak less out of the pinion seal.
