Vacuum Pump lines and connection
My vacuum pump should be here any day now. We need to figure out what is the best way to hook up the vacuum pump to the crankcase. I would like to connect it to the valley cover but we would need to weld some fittings which is fine. Any creative solutions?
Phil
Phil
You can use a ls1 valley cover and a 12 an fitting with the rubber o ring. Same thing you use on the plastic tank to sump it. I can send you a picture when we get it done in a week or so.
