Broke 5 of my Taylor wires taking the bastards off today
Old 12-21-2005, 06:11 PM
Quickin's Avatar
Default Broke 5 of my Taylor wires taking the bastards off today
Thats it, I'm just pissed. They all broke with the lead staying on the spark plug. Good thing I kept my stock wires, which seem to run exactly the same as the friggin Taylors
Old 12-21-2005, 06:26 PM
Black Z/28's Avatar
How many times have you removed your Taylor's since the original install? I've only removed mine once since I put them on and they came out just fine. I had been reading these complaints about the Taylors so I was extra careful- but I wouldn't buy them again.
Old 12-21-2005, 06:36 PM
11 Bravo's Avatar
Quite a few posts similar posts about the Taylors. It has happened to me. Thankfully I also had my stock wires still. For the money, they suck.
Old 12-21-2005, 07:19 PM
Forced370GTO's Avatar
same problem here...
Old 12-21-2005, 07:26 PM
GM Muscle's Avatar
Damn, I must have gotten lucky. I'm always ripping mine off to pull plugs and I havn't had any issues. I believe that they are 3 years old now. Guess I'll have to be more careful.
blkZ28spt's Avatar
There are two different taylor wires. The cheaper ones seem to always end up like this.
Old 12-21-2005, 07:27 PM
Ferocity02's Avatar
Happened to me too with my 409's. I only broke two of them. Do your best to pull on the boot, not the wire, and they will last a little longer. I had only removed mine twice before(they broke the third time removing them, about 8k miles on them). Now I have the Thundervolts.
Old 12-21-2005, 07:50 PM
Bo White's Avatar
I worked at a speed shop for 4 years that sold Taylors mostly and I never seen any problems with them or the ones I had(although I have seen a few over head cam plug wires that wouldnt stay plugged in but I replaced em with no problems). Pulling on the boot is the only way your supposed to remove them although sometimes hard to get to I will admit lol. I have seen some of the threads and most problems that I have seen on here is were they pull on the wire. Its another one of those things were you run the brands that you have the best luck with.
Old 12-21-2005, 08:20 PM
Quickin's Avatar
I didn't only pull on the boot, I used a set a dykes to actually pull them off like a boot puller would do, they broke anyway. Leaving the lead on the tip of the plug. Mine were the Thunderbolt 50, 10.4 mm. I figured **** the other 3 wires since I'd need a new set anyway so I just grabbed the wire itself (not even the boots) and just yanked them off, those 3 came off perfectly fine and quite easy.
The easy ones were the front 3 on the drivers side, the coolest of the 8 anyway. Maybe the heat from my LT's??????
After just taking about a 30 mile joyride on I-95 (see-moked a turbo Eclipse with a fartpipe ) and the car runs better, just too perfect....stock wires are just fine, no need to waste money on aftermarket wires.
Old 12-21-2005, 08:25 PM
Bo White's Avatar
Yeah, the stock GM wires work just fine IMO. Thats whats on my car, although they have 118k miles on em lol. Still going.......
Old 12-21-2005, 08:46 PM
Quickin's Avatar
I still made sure to slap a bunch of dielectric grease all over them though
Old 12-21-2005, 09:05 PM
00SS4780's Avatar
Here is a pic of my 409!
Old 12-21-2005, 09:27 PM
Quickin's Avatar
Thats what all my broken ones looked like, except each one had a long thin wire unspooling from them as a pulled them off and out.
Old 12-21-2005, 09:37 PM
00SS4780's Avatar
Yep just like mine! The car wasn't running good so I thought I might have foulded a plug or two. I go to grab that one and it was broke on the plug. The plug was jet black and dripping of gas! Not sure when it had broken. I might have broken it puttin back on the last time. I put MSD's back on mine.
Old 12-21-2005, 09:44 PM
Quickin's Avatar
It's like your car slappin ya in the face when the sum-bitch breaks off in your hand. I'm not gonna polish the bitch until next year now. Oh, thats just over a week away. The car always wins.
Old 12-21-2005, 10:33 PM
1QuickT-A's Avatar
buy some MSDs...
Old 12-21-2005, 11:32 PM
ZL1Killa's Avatar
i got these and have since had no problems at all
think they are the taylor thundervolt wires...got em from thunderracing
Attached Thumbnails Broke 5 of my Taylor wires taking the bastards off today-dcp_1245.jpg
Old 12-21-2005, 11:39 PM
Brandon Boomhauer's Avatar
2 Sets of MSDs on 2 different LSx vehicles and not a problem.
I always grease the boot though, makes it much easier on removal.
Old 12-21-2005, 11:57 PM
Mike K.'s Avatar
same thing happened to me with the taylors, stockers back on now.
Old 12-22-2005, 12:10 AM
jrp
SN95 Director
jrp's Avatar
same here.
