stick with my fast 90/90 or
go to the carb style fi.im really thinking about going over to the carb style intake..now heres the deal i shift my car at 7200 sometimes close to 7400...this is a stock 346 cam only motor...im looking for nothing but track numbers..car has a 5500 8 inch converter th 350 4.56 rear end. leaving off the trans brake...and weighs in the high 2700's with me in it..do you think its worth selling my fast 90 to go with this intake...also can i use my nw throttle body or do i have to get the accufab 90 for the 5.0...thanks for the help...forgot to say im also running the t rex cam...thanks
No doubt. For that setup I'd be looking at a GMPP or Edelbrock carb intake.
Here's some reading for you:
https://ls1tech.com/forums/generation-iii-external-engine/105407-carb-intakes-ls1-s.html
https://ls1tech.com/forums/generation-iii-external-engine/112195-new-edelbrock-ls1-intake.html
https://ls1tech.com/forums/generation-iii-external-engine/148639-new-carb-ls1-setup-made-40-hp-over-ls6.html <<results
https://ls1tech.com/forums/generation-iii-external-engine/158658-gmpp-ls1-intake-availbility-update.html
https://ls1tech.com/forums/generation-iii-external-engine/168311-war-intake-accel-teaser-pictures.html
https://ls1tech.com/forums/generation-iii-external-engine/173568-more-war-gmpp-intake-pictures-big-pictures.html
https://ls1tech.com/forums/generation-iii-external-engine/198601-gmpp-singleplane-tested-new-popular-hotrodding-mag.html
https://ls1tech.com/forums/generation-iii-external-engine/267311-carb-ls1-intake-converted-efi.html <<pictures
https://ls1tech.com/forums/generation-iii-external-engine/305750-why-more-people-not-running-gmpp-intake.html <<pictures
https://ls1tech.com/forums/dynamometer-results-comparisons/311005-spm-hptuners-dyno-results.html <<dyno results
https://ls1tech.com/forums/generation-iii-external-engine/314549-carbed-intake-converted-f-i.html
https://ls1tech.com/forums/generation-iii-external-engine/320023-gmpp-carb-efi-conversion.html
https://ls1tech.com/forums/forced-induction/327044-new-intake-arrives.html
https://ls1tech.com/forums/generation-iii-external-engine/334178-who-do-machining-gmpp-single-plane-manifold.html
https://ls1tech.com/forums/generation-iii-external-engine/354540-vic-jr-intake-ls1.html
https://ls1tech.com/forums/generation-iii-external-engine/379735-edelbrock-victor-jr-intake-pics-specs.html <<pictures
https://ls1tech.com/forums/generation-iii-external-engine/381677-various-single-plane-intake-pics-big-pics.html <<pictures
https://ls1tech.com/forums/generation-iii-external-engine/392724-putting-carb-ls1.html <<Lots of Pix
https://ls1tech.com/forums/generation-iii-external-engine/414468-gmpp-intake-vs-edelbrok-victor-jr-ls1.html
https://ls1tech.com/forums/showthread.php?t=105407
https://ls1tech.com/forums/showthread.php?t=112195
https://ls1tech.com/forums/showthread.php?t=148639 <<results
https://ls1tech.com/forums/showthread.php?t=158658
https://ls1tech.com/forums/showthread.php?t=168311
https://ls1tech.com/forums/showthread.php?t=173568
https://ls1tech.com/forums/showthread.php?t=198601
https://ls1tech.com/forums/showthread.php?t=267311 <<pictures
https://ls1tech.com/forums/showthread.php?t=305750 <<pictures
https://ls1tech.com/forums/showthread.php?t=311005 <<dyno results
https://ls1tech.com/forums/showthread.php?t=314549
https://ls1tech.com/forums/showthread.php?t=320023
https://ls1tech.com/forums/showthread.php?t=327044
https://ls1tech.com/forums/showthread.php?t=334178
https://ls1tech.com/forums/showthread.php?t=354540
https://ls1tech.com/forums/showthread.php?t=379735 <<pictures
https://ls1tech.com/forums/showthread.php?t=381677 <<pictures
https://ls1tech.com/forums/showthread.php?t=392724 <<Lots of Pix
https://ls1tech.com/forums/showthread.php?t=414468
