Whining gears: bad install or defective gears?
Old 12-21-2005, 11:24 PM
Slow LT1's Avatar
Default Whining gears: bad install or defective gears?
I have a Currie 9-inch rearend with 4.11 gears that have always whined pretty loudly. Is there any way to tell if they're whining because they weren't setup right or if they're whining because the gears themselves are bad? The reason I ask is because I'm about to drop the center section to change the posi, and am debating replacing the ring and pinion to see if it will reduce the whine. Thanks.
Old 12-22-2005, 05:22 AM
EPP
EPP's Avatar
The only way to see if it is a bad install is to inspect the pattern and measure the backlash. Do you have Richmond gears? They tend to be louder. Bob
Old 12-22-2005, 10:22 AM
Shamson5.7's Avatar
I am having the same problem in 5th and 6th gears. It whines quite loudly and my rear was just finished being installed 2 days ago.
Old 12-22-2005, 10:26 AM
Retired Street Racer
Matt D's Avatar
I had Richmond gears and they were noisy as hell. I would change the gears to Strange or GM/Motive if I were you.
Old 12-24-2005, 03:50 PM
silver30th's Avatar
i have strange's and they also whine a little, i think its just to be expected
Old 12-25-2005, 03:47 PM
nikon1999's Avatar
i have gm motives and they make a good deal of noise, back lash was checked and rechecked nad its perfect, oh well
Old 12-25-2005, 11:12 PM
Shamson5.7's Avatar
Are you talking about noise while in gear or while shifting into a different gear? I have a clunk sound when im stopped and i put it into 1st w my moser.
Old 12-28-2005, 09:01 PM
nikon1999's Avatar
while in gear
