bumper support
Like GM Muscle said my scale read 14 lbs. for the impact bar and 4 lbs. for the foam. I rented a saw at Low`s and cut the frame rails that the bumper bolted to and saved 5.5 lbs. I also took off all the panneleing under the bumper cover and the washer fluid tank. I rigged up some aluminum 1 inch by 1/8 inch thick brackets to hold the top of the bumper cover up to fit flush with the hood and I slotted the bracket to adjust the gap between the hood and the bumper cover. I did not reuse the bracket that has the two hood levelers on it. I wish DopefedZ would post some pictures of his bumper. I mounted mine back up like he did his. Altogether I saved around 34 lbs.
